Sign in to follow this
SteveF
944 Sunroof has a mind of its own!
Good afternoon all,
I hope that someone may be able to assist with an issue I am having with my '86 model 944. It all started last week when I tried to close my sunroof but it wouldn't close. When I put the ignition key in the Accessory position I can open and lower the sunroof fine. When I turn the ignition key to open it will open but not close. Then with the sunroof closed if I go for a drive it automatically opens.
This weekend I went through the Clarks Garage troubleshooting guide but not having any luck. I have checked the sunroof motor, relay, switch on the lower dash, fuses, directional relays and all seems good. I have come to the conclusion that it is something to do with the limit switches and the sunroof not properly locking so either a broken limit switch or something needs adjusting. . Limited switch shown with the yellow arrow here:
I have tried to adjust the limit switches which slide back and forth along the cable guide but no success. I couldn't see a way to take these out without having to remove the entire cable guide which I would prefer not to do at this stage unless absolutely necessary. The other strange thing is that I have the updated model with the new dash but what looks to be the previous model sunroof setup. My car is a very early series two so maybe that is why.
May I ask if anyone has any thoughts on how to progress with this one it would be greatly appreciated.
Steve
Share this post
Link to post
Have you tried having a look at the switch up between the sun visors.  That one, if I recall correctly (it's been a few years since I did this) tells the car whether or not the sunroof is fitted.
Why Porsche bothered bringing the sunroof cars into Oz escapes me...
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
