grantmr Posted 8June, 2017 Report Share Posted 8June, 2017 ^ What Jeff said. They literally do this for rust prevention on old steam engines. Link to comment Share on other sites More sharing options...
rafikdous Posted 11June, 2017 Author Report Share Posted 11June, 2017 Can someone remind me where these washers go? Link to comment Share on other sites More sharing options...
81SC Posted 11June, 2017 Report Share Posted 11June, 2017 ^ They are the lock tab washers for the front top strut mount nut, in the front trunk. Part no. 900 038 002 01. Link to comment Share on other sites More sharing options...
firstone Posted 11June, 2017 Report Share Posted 11June, 2017 ^ They are the lock tab washers for the front top strut mount nut, in the front trunk. Part no. 900 038 002 01.Gold. looks like they are fuched? Link to comment Share on other sites More sharing options...
rafikdous Posted 12June, 2017 Author Report Share Posted 12June, 2017 I replaced them already. That's why I ended up with a spare pair and couldn't remember what they are Link to comment Share on other sites More sharing options...
Raven Posted 12June, 2017 Report Share Posted 12June, 2017 you should always end up with some nuts bolts and washers left over ...........it just happens Link to comment Share on other sites More sharing options...
rafikdous Posted 18June, 2017 Author Report Share Posted 18June, 2017 Been working quietly on the rear brakes and axles. Just need to bolt back the rotors and backing plates Link to comment Share on other sites More sharing options...
rafikdous Posted 19June, 2017 Author Report Share Posted 19June, 2017 And the genius who worked on the car before, decided that only one handbrake expander is needed on the left side and just replaced the other one with a washer!!!I ordered one from Porsche, pick it up tomorrow so I can finish the other side and start bleeding the system Link to comment Share on other sites More sharing options...
rafikdous Posted 20June, 2017 Author Report Share Posted 20June, 2017 Got some weird part from Porsche today, no idea what it is. The part number is correct for the h/brake expanding bow but the part inside is a rubber strip!!Will go in tomorrow to sort it out Link to comment Share on other sites More sharing options...
rafikdous Posted 22June, 2017 Author Report Share Posted 22June, 2017 This morning's work. Gee its difficult to get out of bed at 5am in 4deg temp to get into a garage and work on the car Link to comment Share on other sites More sharing options...
rafikdous Posted 29June, 2017 Author Report Share Posted 29June, 2017 Stripped and etch prined Painted and hardware replated Link to comment Share on other sites More sharing options...
rafikdous Posted 29June, 2017 Author Report Share Posted 29June, 2017 More stuff back from replatting Refurbished engine mounts in place. Had to use a hydraulic press to force the old rubbers out and new ones in Link to comment Share on other sites More sharing options...
rafikdous Posted 1July, 2017 Author Report Share Posted 1July, 2017 I wasn't happy with how the rear brake lines turned out so pulled them from the main line in the tunnel backwards and started again Bloody difficult to not cross thread the brake nuts when there is no sensation in your figures whatsoever. 1 deg this morning Anyway, all lines are done and happy with them so now to bleeding the ststemnew pads, replated pins and new clips Link to comment Share on other sites More sharing options...
rafikdous Posted 4July, 2017 Author Report Share Posted 4July, 2017 Bit of a set back with the brakes unfortunatelyAfter fitting everything including the reco'd master cylinderUsed my trusted pneumatic bleeder to bleed the system All good so far except even after completely bleeding the system, no pressure whatsoever at the pedalChecked everything twice and three times, still nothingOff the master cylinder came which is a complete pain in the royal a#$@. Took it to the braking place, bore is shot and will need re-sleevingSo nothing will happen brake wise for a weekOn the "bright" side, picked up some more parts from the plating place. Looking great Link to comment Share on other sites More sharing options...
LeeM Posted 4July, 2017 Report Share Posted 4July, 2017 Get a new double outlet master cylinder Raf Link to comment Share on other sites More sharing options...
rafikdous Posted 4July, 2017 Author Report Share Posted 4July, 2017 Hi Lee, its already dual circuit mate Link to comment Share on other sites More sharing options...
LeeM Posted 4July, 2017 Report Share Posted 4July, 2017 Hi Lee, its already dual circuit mate? Ignore me then mate Link to comment Share on other sites More sharing options...
rafikdous Posted 16July, 2017 Author Report Share Posted 16July, 2017 Master cylinder is back and in place now. Bled the system but still have spongy pedal. So will need to do more bleeding Been tidying up the wiring in the engine bay and fitting the tail lights Link to comment Share on other sites More sharing options...
rafikdous Posted 24July, 2017 Author Report Share Posted 24July, 2017 Still working on the rear of the car. Next will be to fit the bumpersDid the inside of them this morningBefore And after Link to comment Share on other sites More sharing options...
rafikdous Posted 24July, 2017 Author Report Share Posted 24July, 2017 How many different parts does it take to put a bumper together??seriously Porsche went overboard with this a little. And that's not even all. The end caps aren't included in the picture!! Link to comment Share on other sites More sharing options...
LeeM Posted 25July, 2017 Report Share Posted 25July, 2017 Then you gotta put them back on correctly without scratching the body which can be fun! ? The bumper to body rubber was my NNNNGH FFFFFFFF.....N moment ?? Link to comment Share on other sites More sharing options...
rafikdous Posted 28July, 2017 Author Report Share Posted 28July, 2017 Here is how I am doing itmasking tape then marketed the edge of the guard on it. Will remove the bumper again then cut the inside part of the tape then stick the rubber along the inside of the line Link to comment Share on other sites More sharing options...
LeeM Posted 28July, 2017 Report Share Posted 28July, 2017 That's how I SHOULD have done it. Ya learn by your mistakes sometimes Link to comment Share on other sites More sharing options...
rafikdous Posted 28July, 2017 Author Report Share Posted 28July, 2017 So you reckon this is the way to go before I continue? Link to comment Share on other sites More sharing options...
LeeM Posted 28July, 2017 Report Share Posted 28July, 2017 Yep. Just double tape the body where it meets the bumper to ensure no scratches Link to comment Share on other sites More sharing options...
