911sc Missing rocker cover stud
NaFe
I've recently discovered that I'm missing a lower rocker cover stud. I have bought a new one to fit but was wondering whether I should loctite it place. I was hoping to find the answer in the How to Rebuild and Modify Porsche 911 book but it simply shows the them already fitted.
Not sure whether the just tighten the stud or whether I should use smke type of loctite. If not any ideas of the torque?
Nathan
Nathan,
Ideally with the cover off, check the stud hole is clean, tighten two suitable nuts together on the outer end of the stud using two spanners, apply suitable Loctite to the other end and screw in and tighten to "gently snug".  Release the nuts and reinstall the cover.
Nathan,
That's the exact method I was planning on using, so thanks for confirming my thoughts.  Any preference on loctite number I should use?
Cheers, Nath
Loctite 270.  Ideally, clean all threads with loctite cleaner / degreaser, but wax 7 grease remover is OK.  You can also give it a good clean with Loctite Primer N, which is also an activator & bond enhancer, but don't inhale this stuff.  It'll make you gag for a month.
