Timm Posted 7June, 2018 Report Share Posted 7June, 2018 Hey guys, anyone know what tie rods would go into an RHD 86 951? (early offset, power rack) From what I've read, RHD and LHD are supposedly the same..but looking at pictures mine at least are different where the outer end of the boot slips on. I was going to buy these. https://www.ebay.com.au/itm/401490345378 Here is what my mine look like: Link to comment Share on other sites More sharing options...
Buchanan Automotive Posted 7June, 2018 Report Share Posted 7June, 2018 944 347 033 20 = 944 & Turbo with power steering 1985 & 1986 ONLY , all new tie rods come with new tie rod ends ( joint ) Note } the 1987 - 1995 Tie Rods are longer Link to comment Share on other sites More sharing options...
Timm Posted 7June, 2018 Author Report Share Posted 7June, 2018 19 minutes ago, Buchanan Automotive said: 944 347 033 20 = 944 & Turbo with power steering 1985 & 1986 ONLY , all new tie rods come with new tie rod ends ( joint ) Note } the 1987 - 1995 Tie Rods are longer Thanks! So they should fit then...which makes me wonder what's in my car now? Because it doesn't look like my boots will fit those rods, so will have to get new boots as well. This is how my outer boot ends slip onto the rod: Link to comment Share on other sites More sharing options...
Buchanan Automotive Posted 7June, 2018 Report Share Posted 7June, 2018 You have NON 944 rack boots on you're car now , hence why its not quite right & the Zip Tie and the little metal clamp is all aftermarket "generic" stuff ( Holden Commodore stuff ) The rack boot part numbers for the correct tie rods are 171 419 831 C X 2 ( power steer / R/H/D ) Link to comment Share on other sites More sharing options...
9fan Posted 7June, 2018 Report Share Posted 7June, 2018 Love your work Bruce ! Link to comment Share on other sites More sharing options...
