BRAUN911 Posted 13June, 2018 Report Share Posted 13June, 2018 I have always problem opening the drivers door from the outside so decided to dismantle and investigate. looks like the problem is a bent door latch assembly, would be from PO long time back. would anyone have a drivers side latch assembly to suit a 74 911 they are will to part with? Also trying to get side window cranking up and down easier, is there a measurement spec where the bottom rail is positioned on the glass? Thanks in advance Martin Link to comment Share on other sites More sharing options...
Jason A Posted 14June, 2018 Report Share Posted 14June, 2018 Best to pick one up from eBay in the US -,that’s where I got mine. Expect to pay around $200. Benefit over there is passengers side, so a lot less use. Link to comment Share on other sites More sharing options...
Zelrik911 Posted 19June, 2018 Report Share Posted 19June, 2018 On 6/13/2018 at 7:28 PM, BRAUN911 said: I have always problem opening the drivers door from the outside so decided to dismantle and investigate. looks like the problem is a bent door latch assembly, would be from PO long time back. would anyone have a drivers side latch assembly to suit a 74 911 they are will to part with? Hi Martin I have a Latch mechanism that I removed from a '77 - I fitted a near new later one that I got from Canada for next to nothing. The original latch has some welding on the pins but looks straight. I was going to chuck it, but there may be good bits & pieces you can cannibalize - so you are welcome to it. Peter Melb. Link to comment Share on other sites More sharing options...
