Timm Posted 18June, 2018 Report Share Posted 18June, 2018 I'm looking for some 968 castor blocks...the rubber can be in any condition as I want to put poly bushings in them. Alternatively...if anyone has some nice spherical joints I would like to buy them Also, if anyone here has upgraded their control arm bushings I wouldn't mind hearing your feedback. I'm on the fence about forking out for proper spherical bearings, or going for powerflex or similar poly bushings. Link to comment Share on other sites More sharing options...
OzJustin Posted 18June, 2018 Report Share Posted 18June, 2018 Hi Tim I just ordered a set of the 968 castor blocks for my S2. They were $167 for the pair from BWA if that helps. Probably worth finding a cheaper used set if you want to put poly in them though. I might put Powerflex black bushings in mine when I wear them out. Could be a while though. Link to comment Share on other sites More sharing options...
Timm Posted 18June, 2018 Author Report Share Posted 18June, 2018 43 minutes ago, OzJustin said: Hi Tim I just ordered a set of the 968 castor blocks for my S2. They were $167 for the pair from BWA if that helps. Probably worth finding a cheaper used set if you want to put poly in them though. I might put Powerflex black bushings in mine when I wear them out. Could be a while though. Thanks, that's a good price. I'm still running the stock 944 items, so even some new 968 blocks with the stock rubber will be an upgrade. But yes, I was thinking of going straight to Powerflex black bushings if I find a cheap used set. Link to comment Share on other sites More sharing options...
OzJustin Posted 18June, 2018 Report Share Posted 18June, 2018 9 hours ago, Timm said: Thanks, that's a good price. I'm still running the stock 944 items, so even some new 968 blocks with the stock rubber will be an upgrade. But yes, I was thinking of going straight to Powerflex black bushings if I find a cheap used set. Sounds like a plan. I’ll be curious to hear what you think of the Powerflex black and whether they’re too harsh for the street. They have the slightly softer purple ones too. Link to comment Share on other sites More sharing options...
