SteveF Posted 24June, 2018 Report Share Posted 24June, 2018 I’m doing a tidy of a few things in the interior of my ‘86 944 and wonder if anyone has a working digital clock and/or the black dash trim that surrounds it and runs across the glove box to the a/c vent? Thanks Steve Link to comment Share on other sites More sharing options...
Jason E Posted 25June, 2018 Report Share Posted 25June, 2018 Hi Steve, you probably know this but you can get very good kits to fix the clock of ebay. If I can fix it anyone can. I picked up a good bit of trim from Aporschapart in Vic - they are pricey at times. Try your local Porsche Centre - they can be surprisingly good value. Link to comment Share on other sites More sharing options...
SteveF Posted 26June, 2018 Author Report Share Posted 26June, 2018 Thanks Jason. I think that is the way to go in terms of the kit. There seems to be a few around. Aporscha part have a trim piece in stock as well! Link to comment Share on other sites More sharing options...
Jason E Posted 26June, 2018 Report Share Posted 26June, 2018 I know there are a few places in the States & the UK that do reconditioned clocks however I surprised myself by actually fixing mine successfully. I can't recall which crew I got it from on ebay but they where good. I just looked at the reviews & went with who had the best seller rating. Do yourself a favour & check the prices at your local Porsche Centre for the trim piece. They have surprised me a few times with being only narrowly more expensive than second hand parts on certain items. I always check the new price as a first port of call. I but lots of gear from OS but it's the freight that makes it murderous.............. Link to comment Share on other sites More sharing options...
SteveF Posted 26June, 2018 Author Report Share Posted 26June, 2018 Good advice. Thanks Jason. Aporsha Part want $85 for a second hand one so I’ll check Porsche Willoughby to compare. I’ll also get a kit and give a crack at repairing the clock. Link to comment Share on other sites More sharing options...
Jason E Posted 26June, 2018 Report Share Posted 26June, 2018 9 hours ago, SteveF said: Good advice. Thanks Jason. Aporsha Part want $85 for a second hand one so I’ll check Porsche Willoughby to compare. I’ll also get a kit and give a crack at repairing the clock. You probably can't beat $85 - if it is in good order. My clock kit came with good instructions but I also looked deeply into clarks garage & they had some good tips on what to look out for & what to avoid to do unnecessary damage . Also remember that the light bulb on the clock may want replacing as well. I didn't realise this & put my clock together & reinstalled it only to find that the bulb didn't work. I ordered one for a few dollars from Porsche & will reinstall next time the dash is out. It needs to be soldered in. Link to comment Share on other sites More sharing options...
Stepo Posted 27June, 2018 Report Share Posted 27June, 2018 3 hours ago, Jason E said: It needs to be soldered in. The globe doesn't need to be soldered in for an S2, presume 86 is the same? Watch the video below, see from 11:55 I couldn't find WPO shop on ebay any longer? NEW purchase? https://www.ebay.com.au/itm/Porsche-944-968CS-digital-clock-LCD-screen-repair-kit/122182345640?epid=856068849&hash=item1c72a2a3a8:g:vMUAAOSw7z1aIGqY Link to comment Share on other sites More sharing options...
SteveF Posted 27June, 2018 Author Report Share Posted 27June, 2018 Thanks gents. I was going to order through Frazerparts as I have usd them before so your link was reading my mind!!! I couldn’t find the WPO shop either. Link to comment Share on other sites More sharing options...
Jason E Posted 28June, 2018 Report Share Posted 28June, 2018 23 hours ago, Stepo said: The globe doesn't need to be soldered in for an S2, presume 86 is the same? Watch the video below, see from 11:55 I couldn't find WPO shop on ebay any longer? NEW purchase? https://www.ebay.com.au/itm/Porsche-944-968CS-digital-clock-LCD-screen-repair-kit/122182345640?epid=856068849&hash=item1c72a2a3a8:g:vMUAAOSw7z1aIGqY Well shit. Wish I'd watched this vid prior to doing mine. I fiddled with my bulb & it felt too solid to be just "clipped" in. Did some very scant research & read something that said it was soldered in there. Now I have to pull the wholw bloody thing apart again. Bugger................................ Thanks for the link @Stepo. Just to confirm can you all read your clocks at night? Mine's fine during the day but unreadable at night. Link to comment Share on other sites More sharing options...
Stepo Posted 28June, 2018 Report Share Posted 28June, 2018 6 hours ago, Jason E said: Just to confirm can you all read your clocks at night? Mine's fine during the day but unreadable at night. The globe is your issue if you can't see the numbers at night Link to comment Share on other sites More sharing options...
Jason E Posted 28June, 2018 Report Share Posted 28June, 2018 11 minutes ago, Stepo said: The globe is your issue if you can't see the numbers at night Thought so, thanks. Looks like I am pulling the mongrel thing apart again. Link to comment Share on other sites More sharing options...
SteveF Posted 7July, 2018 Author Report Share Posted 7July, 2018 Got my kit and are in the process of doing it. Just to clarify does the bulb need to be soldered in or not? A bulb came with the kit but doesn’t work when I turn on the lights so are assuming yes or it could be something else. Link to comment Share on other sites More sharing options...
Jason E Posted 7July, 2018 Report Share Posted 7July, 2018 just twists in. Watch the video that was posted - very informative - JAVOL !!!!! Link to comment Share on other sites More sharing options...
SteveF Posted 7July, 2018 Author Report Share Posted 7July, 2018 Thanks Jason. Javol, the vid was very helpful with the installation and clock works great but still having issues with getting the light to work. There appears to be power going to the socket that the clock and light plugs into. I even tried doing it again with a second clock that I found online and the same issue. I shall keep trying. If anyone has any ideas please let me know. Link to comment Share on other sites More sharing options...
Jason E Posted 8July, 2018 Report Share Posted 8July, 2018 That's me stumped, not sure, hopefully someone with some helpful comments will chime in?. Link to comment Share on other sites More sharing options...
Stepo Posted 8July, 2018 Report Share Posted 8July, 2018 On 7/7/2018 at 6:49 PM, SteveF said: Thanks Jason. Javol, the vid was very helpful with the installation and clock works great but still having issues with getting the light to work. There appears to be power going to the socket that the clock and light plugs into. I even tried doing it again with a second clock that I found online and the same issue. I shall keep trying. If anyone has any ideas please let me know. Does the globe come on when you turn your headlights on Steve? Link to comment Share on other sites More sharing options...
Dreamr Posted 8July, 2018 Report Share Posted 8July, 2018 1 hour ago, Stepo said: Does the globe come on when you turn your headlights on Steve? Hey Stepo, I've been working on this with Steve and I can't work out what is going on ... We've ascertained with a test light that the power terminal on the plug side has power and goes on and off with the parkers... the new globe that came with the clock kit is also soldered in to the holder, so no issues there ... The only 2 things I can think of is .. 1. The plug "may" have an earth terminal that works in conjunction with the power terminal for the clock alone ... I haven't tested the plug to see if the earth terminals are good ... So I'm thinking a power and earth for the clock circuit and the same for the light circuit. 2. There is a break somewhere in the circuitry on the clock ... I'm a little hesitant to think this option as 2 x clocks don't light the globe and it's odd that both don't work ... (same soldered globe). Are you aware of any other common issues that would stop it from working?? Link to comment Share on other sites More sharing options...
