Mike D'Silva Posted 24July, 2018 Report Share Posted 24July, 2018 My car has the huge USA spec rear bumperettes and I am looking either to find a set of the Aus spec ones, or perhaps even run the car without them at all. However, the bumperettes also have the lights for the rear licence plate. What have people used to light their rears, if not using any bumperette? I was thinking something like this: https://www.ebay.com.au/itm/12V-Rear-White-LED-License-Plate-Bolt-Light-Universal-Fit-Motorcycle-Car-UTV-ATV/232645891843?epid=14013899290&hash=item362ac69703%3Ag%3A600AAOSwDVtabT6y&_sacat=0&_nkw=rear+licence+plate+light&_from=R40&rt=nc&_trksid=m570.l1313 Or one of these, either side.. https://www.ebay.com.au/itm/LED-Rear-License-Number-Plate-Light-Lamp-Truck-Boat-Caravan-Trailer-12-24V-LA/113132807703?epid=4020049940&hash=item1a573da617%3Ag%3AUycAAOSwmypbPtbx&LH_PrefLoc=1&_sacat=0&_nkw=rear+licence+plate+light&_from=R40&rt=nc Link to comment Share on other sites More sharing options...
SC 3.2 Posted 24July, 2018 Report Share Posted 24July, 2018 Hi Mike,I used the small motorcycle ones after fitting a plastic rear bumper on my SC and they work a treat,they secure the plate and provide great illumination. Best part is no need to drill holes in your bumper to mount the large original style ones.Sorry can not attach photos on this forum Pete Link to comment Share on other sites More sharing options...
P-Kay Posted 24July, 2018 Report Share Posted 24July, 2018 I recently watched a youtube video where speed academy used these same bullet type as described by SC3.2 above Illuminated plenty fine in my eyes. For $2 how can you go wrong? Link to comment Share on other sites More sharing options...
clutch-monkey Posted 24July, 2018 Report Share Posted 24July, 2018 mike, i used something like these, the bolt type ones work ok. https://www.revzilla.com/motorcycle/speedmetal-led-license-plate-bolts edit: actually i still have them on the shelf, looks like i have not bothered to install them in the last 7 years.. oh well. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 24July, 2018 Author Report Share Posted 24July, 2018 yeah, the only thing I was thinking of, was access to the rear to tighten the nut for when you wanted to remove/change the plate.. but I will probably do it anyway. Thanks for chiming in. Link to comment Share on other sites More sharing options...
Fraz Posted 25July, 2018 Report Share Posted 25July, 2018 I have used a set of these. https://jaydeeautocables.com.au/collections/trailer-lights Link to comment Share on other sites More sharing options...
MFX Posted 25July, 2018 Report Share Posted 25July, 2018 1 hour ago, Mike D'Silva said: yeah, the only thing I was thinking of, was access to the rear to tighten the nut for when you wanted to remove/change the plate.. but I will probably do it anyway. Thanks for chiming in. That is definitely an issue. I used the same bike ones on my car. Just put some spade connections in the cables to make it easy to change the plate. Link to comment Share on other sites More sharing options...
P-Kay Posted 25July, 2018 Report Share Posted 25July, 2018 You're changing the number plate often for a nightly drive by? ? Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 25July, 2018 Author Report Share Posted 25July, 2018 oops, I've said too much... Link to comment Share on other sites More sharing options...
LeeM Posted 25July, 2018 Report Share Posted 25July, 2018 I used a stick on LED from Autopro that I attached to the bottom of the decklid like early 911's. Works a treat and is hidden. Will post a pic shortly Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 25July, 2018 Author Report Share Posted 25July, 2018 Lee, that's a pretty clean and clever solution. Link to comment Share on other sites More sharing options...
LeeM Posted 25July, 2018 Report Share Posted 25July, 2018 1 hour ago, Mike D'Silva said: Lee, that's a pretty clean and clever solution. Cheap too at $14 and I have a spare one for the front/froot/frunk. I was going to fit 2 like an early car, but it was waaay too bright I just used some industrial double sided tape, as what it comes with is pretty pathetic, and drilled a small 3mm hole for the wiring then stuck it on ? Link to comment Share on other sites More sharing options...
BlitzKonig Posted 6August, 2018 Report Share Posted 6August, 2018 As has been brought up before, I use these motorcycle LED stubs. Havent had any issue with the police. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 6August, 2018 Author Report Share Posted 6August, 2018 How to mod the bumper so it has no external bolts? Link to comment Share on other sites More sharing options...
BlitzKonig Posted 7August, 2018 Report Share Posted 7August, 2018 23 hours ago, Mike D'Silva said: How to mod the bumper so it has no external bolts? If I told you, you wouldnt believe me. Link to comment Share on other sites More sharing options...
Timm Posted 7August, 2018 Report Share Posted 7August, 2018 2 hours ago, BlitzKonig said: If I told you, you wouldnt believe me. It's zip ties isn't it Link to comment Share on other sites More sharing options...
Stew F Posted 7August, 2018 Report Share Posted 7August, 2018 On 8/6/2018 at 2:15 PM, Mike D'Silva said: How to mod the bumper so it has no external bolts? This is what I want to know. Save me workin shit out. I've thought about welding the holes up, and welding new brackets on the inside of the bumper. Probably need to rehash the mounts on the body. Link to comment Share on other sites More sharing options...
LeeM Posted 7August, 2018 Report Share Posted 7August, 2018 Man you guys know how to make work for yourselves ? Why not attach to under the decklid like mine above? Even if you find a light that needs holes drilled early 911 style or whatever (unlike my stick on one which hasn't moved) it would save having a light on the bumper or re engineering the whole bumper and getting the welder out and looks a lot cleaner. You could even do l.e.d strip lighting that you won't see Link to comment Share on other sites More sharing options...
BlitzKonig Posted 9August, 2018 Report Share Posted 9August, 2018 On 8/8/2018 at 8:34 AM, LeeM said: Man you guys know how to make work for yourselves ? Why not attach to under the decklid like mine above? Even if you find a light that needs holes drilled early 911 style or whatever (unlike my stick on one which hasn't moved) it would save having a light on the bumper or re engineering the whole bumper and getting the welder out and looks a lot cleaner. You could even do l.e.d strip lighting that you won't see It is super clean and much better visibility. These bolt LED are pretty poor in light quality (good or bad thing I guess). Regarding the bumper mods... mine is a Fibreglass piece, so its light and is just held in place by some bolts on the underside to the guards and the centre piece. Link to comment Share on other sites More sharing options...
clutch-monkey Posted 9August, 2018 Report Share Posted 9August, 2018 On 8/8/2018 at 8:34 AM, LeeM said: Man you guys know how to make work for yourselves ? Why not attach to under the decklid like mine above? Even if you find a light that needs holes drilled early 911 style or whatever (unlike my stick on one which hasn't moved) it would save having a light on the bumper or re engineering the whole bumper and getting the welder out and looks a lot cleaner. You could even do l.e.d strip lighting that you won't see I ended up not putting lights in at all, took zero work Link to comment Share on other sites More sharing options...
