Nu2Pcars Posted 30July, 2018 Report Share Posted 30July, 2018 Coolant leak detected from one of the hoses. May require the engine to be dropped to replace. Car with DHM at present. Any words of advice or similar experiences from the brains trust, please?? Link to comment Share on other sites More sharing options...
Raven Posted 30July, 2018 Report Share Posted 30July, 2018 Common issue coolant pipe ends on GT1 based motors are glued in with a resin type glue ,,,,,,and the resin over time brakes down and you start to get a coolant pipe leak or the end just blows out ,,,on a GT3 you can pin the pipes and or re glue not sure on a turbo because you have extra plumbing to negotiate around ...? Many threads on this issue on the Rennlist and other dedicated Porsche forums ,,,,this is not a common problem in Australia seems to be more common in North America ,,,Had a friend with a 996 gt3 he did a engine removal ,,,purchased new after market pipe ends from sharkwerks and had them welded in ..Some owners pin ,,,some re glue and others weld .. His car was a dedicated track car and he didnt want the issue happening again as he dumped coolant all over the track and had a spin in the process.. These are generally the main culprits .....link to a quick explanation of the issue and a Pdf that talks in detail about the problem ,as I said many detailed threads on Rennlist about this .. http://www.mcilvainmotors.com/service/coolant-line-pinning/ image of ends being pined Re glue and knurling Link to comment Share on other sites More sharing options...
