floorprawn Posted 22August, 2018 Report Share Posted 22August, 2018 Hi guys, So my 944's hatch glass is pulling out of the frame at the top, and there's enough of a gap that it's officially bothering me now. I'm not sure whether I should be looking for an entire replacement hatch assembly at this stage or seeing about having the existing one re-done. Is there anyone around the Sydney-ish area confirmed to be able to repair these things? I suppose I could look into DIY repairs but it's a very big expensive piece of glass and I'm not really confident enough to tackle it myself! Thanks in advance for any and all suggestions... Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 22August, 2018 Report Share Posted 22August, 2018 @TINGY944 is the resident expert ... he should see this soon and chime in .. ? Quote Link to comment Share on other sites More sharing options...
Stepo Posted 22August, 2018 Report Share Posted 22August, 2018 It can be a common problem due to the weight of the glass and flimsy frame working over many years. There are many google results from searching US forums. I'd also give the resident NSW guru @Buchanan Automotive a call to review your options as I expect an attempt to repair yourself isn't for the faint hearted. Let us know how you go. Quote Link to comment Share on other sites More sharing options...
TINGY Posted 22August, 2018 Report Share Posted 22August, 2018 1 hour ago, Dreamr said: @TINGY944 is the resident expert ... he should see this soon and chime in .. ? I am definitely not the expert on fixing this problem, maybe how to minimize it from happening but that is another story. I almost fixed mine when i had my first 944 but i could only find 1 guy who knew a guy who knew a guy, that could maybe fix it because he had done it years ago. Bruce and Sean Buchanan would be my go to for this problem, good luck with it i hope you get it fixed. Dreamr 1 Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 22August, 2018 Report Share Posted 22August, 2018 floorprawn would you mind posting a photo or 2? I don't think I have a problem, but I have time to add additional issues to mine to mull over. good luck Rob 1 Quote Link to comment Share on other sites More sharing options...
9fan Posted 22August, 2018 Report Share Posted 22August, 2018 My advice - hunt down suitable replacement from wreckers, worked for me in the past. Quote Link to comment Share on other sites More sharing options...
tazzieman Posted 23August, 2018 Report Share Posted 23August, 2018 There is a method of gluing it back , Rennlist/Pelican had a thread on this. One problem is the hatch shocks are by necessity very strong and continually try to push the frame apart. I took mine off, but you need a healthy shoulder to lift the hatch each time. It's ridiculously heavy. Quote Link to comment Share on other sites More sharing options...
Stepo Posted 23August, 2018 Report Share Posted 23August, 2018 Some light reading for you @floorprawn https://www.pelicanparts.com/techarticles/944_hatch_glass_repair/944_hatch_glass_repair2.htm Quote Link to comment Share on other sites More sharing options...
floorprawn Posted 23August, 2018 Author Report Share Posted 23August, 2018 Thanks for the input guys. As requested here's a photo of how it's currently looking: brian in buddina 1 Quote Link to comment Share on other sites More sharing options...
TINGY Posted 24August, 2018 Report Share Posted 24August, 2018 Just found this https://www.gumtree.com.au/s-ad/adelaide-cbd/wrecking/porsche-wreaking-944-glass-hatch/1191161531 floorprawn 1 Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 6September, 2018 Report Share Posted 6September, 2018 @floorprawn Just saw this on Gumtree ... no affiliation ... https://www.gumtree.com.au/s-ad/glenwood/other-parts-accessories/porsche-924-944-968-hatch-repair/1169279600 Quote Link to comment Share on other sites More sharing options...
Corki944 Posted 10September, 2018 Report Share Posted 10September, 2018 I have a spare one available, let me know what its worth too you....? Quote Link to comment Share on other sites More sharing options...
floorprawn Posted 10September, 2018 Author Report Share Posted 10September, 2018 6 hours ago, Corki944 said: I have a spare one available, let me know what its worth too you....? Oh, really? I missed out on the one Tingy linked on Gumtree, so I am rather interested. Are you able to send me a couple of photos? Quote Link to comment Share on other sites More sharing options...
Rod C Posted 29September, 2018 Report Share Posted 29September, 2018 I had one reglued last year and it came up a treat.A friend of mine who is a professional car glazier and has done a few did the work in two stages as I wanted time to clean and prep the trim for painting. Once the frame was fitted we left it off the car for a few days to set before refitting. We did spend a bit of time filling all the gaps between the frame and the glass also don't rush the separation of the original glue as you could damage the glass. Quote Link to comment Share on other sites More sharing options...
OzJustin Posted 17June, 2019 Report Share Posted 17June, 2019 Digging up an old thread. Does anyone have a glass fitter/resealer in Brisbane they can recommend? My S2 hatch has developed a hatch leak. It appears the previous attempt to reseal my hatch 2 years ago hasn’t lasted. The sealant is just flaking off with my fingernail. The frame doesn’t look to have separated though. Quote Link to comment Share on other sites More sharing options...
