“Repairing” body schutz
Mike 66
Hi
i notice I have some chips underneath of the car where the schutz has been removed( knocks , chips rust etc) leaving the metal work exposed and the surface rusted. What is the best way to fix and blend these areas with new schutz? The areas around these spots is super tuff and won’t remove easily
guessing wire wheel
grease remover
Por 15 or KBS
then schutz - Wurth and “blow” in with compressed air( read this somewhere that gives factory look?)
then paint
Thanks for your help
Mike
Mike,
For repairing small areas I have found using a cheap 1 inch paint brush that has had its bristles cut to half length and using it to dapple on seam sealer.  As it dries quickly, tapping it gently with your hand smooths the dapples out to give a reasonable representation of schutz.  It is also quick easy and doesn't make a mess that real schutz does.
48 minutes ago, Peter M said:
Mike,
sounds like a great solution!!
