Need a 200mm pressure plate
rafikdous
Whoa! Looks like you will need a new throw-out bearing and/or assembly as well?  The 180 and 200mm pressure plate are compatible with VW parts (Kombi and Transporter), I believe.  However Sachs is generally seen as the best quality.  BWA in Sydney have them normally.  My spares are 180mm.
  • 2 weeks later...
thanks Merv
I ended up getting mine from AA Pistons in the USA
Fitted it on the weekend. Works now but the pedal travel is still too long. Probably about 50 to 70mm of free travel. So need to do some adjustments still
  • 3 weeks later...
