7smurfs Posted 25January, 2019 Report Share Posted 25January, 2019 Anyone had to go through the experience of having to replace the LED in their fog lights? My left one is no longer working, however, am unsure whether I can simply change the LED DIY or whether I will need to change the entire foglight unit itself. Nothing seems to come up in my quick online search. Any help would be much appreciated! Link to comment Share on other sites More sharing options...
donR Posted 29January, 2019 Report Share Posted 29January, 2019 If you can look up the bulb type and it is standard then you should be able to do it. Even most auto shops sell LED replacements these days. Depending on the intensity you want you will need to check how larger module you can fit as the heat sinks/fans can be largish at the back. You might also need canbus correction. I had to use these for my Audi due to lack of space: Link to comment Share on other sites More sharing options...
