AdRock Posted 25March, 2019 Report Share Posted 25March, 2019 Hi team, I just discovered that my WUR is a number 054, which is apparently suitable for Turbo cars only. The WUR that is correct for my car is a 090. I'm just wondering if anybody happens to have a 090 WUR laying around the shed that they would like to sell to me? Or if you would like to swap for the Turbo version that I currently have as part of my CIS. Cheers. Link to comment Share on other sites More sharing options...
ANF Posted 26March, 2019 Report Share Posted 26March, 2019 Get in contact with these guys, may be able to do you a swap (or help you in some way)? They rebuilt my WUR on exchange basis, good service!! http://k-jet.biz/www.k-jet.biz/index.html Link to comment Share on other sites More sharing options...
AdRock Posted 26March, 2019 Author Report Share Posted 26March, 2019 1 hour ago, ANF said: Get in contact with these guys, may be able to do you a swap (or help you in some way)? They rebuilt my WUR on exchange basis, good service!! http://k-jet.biz/www.k-jet.biz/index.html Thanks mate - will check them out. Still keen to hear though if anybody happens to have one sitting on a shelf somewhere until I pull the trigger on going to a pro. Link to comment Share on other sites More sharing options...
ANF Posted 26March, 2019 Report Share Posted 26March, 2019 They buy WURs as well, to keep up their stock, you may get one pretty cheap! Whatever used one you do get would need to be recalibrated most likely? Mine cost $300 rebuilt. Good luck!! How is your rebuild coming along? Link to comment Share on other sites More sharing options...
AdRock Posted 26March, 2019 Author Report Share Posted 26March, 2019 Just looked at the website - very reasonably priced compared to the US people. Will shoot them a message. Cheers @ANF 4 minutes ago, ANF said: They buy WURs as well, to keep up their stock, you may get one pretty cheap! Whatever used one you do get would need to be recalibrated most likely? Mine cost $300 rebuilt. Good luck!! How is your rebuild coming along? Just getting the cam timing sorted and piston/cylinder clearances checked. Then I can start installing the rest of the valves and rockers, oil cooler and CIS. Although - I have to start sourcing all the vac hoses and fuel lines on the CIS and a correct WUR. Slowly... Slowly..... :s Link to comment Share on other sites More sharing options...
ANF Posted 26March, 2019 Report Share Posted 26March, 2019 It can unfortunately be a slow process..... hopefully I will have all my bits machined soon!! I went through my CIS system before the rebuild, all that stuff is still good! Link to comment Share on other sites More sharing options...
AdRock Posted 28March, 2019 Author Report Share Posted 28March, 2019 On 26/03/2019 at 15:34, ANF said: Get in contact with these guys, may be able to do you a swap (or help you in some way)? They rebuilt my WUR on exchange basis, good service!! http://k-jet.biz/www.k-jet.biz/index.html Got in contact with them. None available. Link to comment Share on other sites More sharing options...
ANF Posted 28March, 2019 Report Share Posted 28March, 2019 Bugger, sorry mate!! I wonder if they can rebuild/ adjust yours to mimic what it should be. Was your car running when you got it (maybe P.O. did that?) Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 28March, 2019 Report Share Posted 28March, 2019 On 26/03/2019 at 15:54, AdRock said: Just getting the cam timing sorted and piston/cylinder clearances checked. Then I can start installing the rest of the valves and rockers, oil cooler and CIS. Although - I have to start sourcing all the vac hoses and fuel lines on the CIS and a correct WUR. Slowly... Slowly..... :s Wouldn't you have checked your piston/cylinder clearances before assembly? Link to comment Share on other sites More sharing options...
AdRock Posted 29March, 2019 Author Report Share Posted 29March, 2019 On 28/03/2019 at 14:08, Mike D'Silva said: Wouldn't you have checked your piston/cylinder clearances before assembly? Ah - good spotting, what I meant was Valve to Piston clearance. Link to comment Share on other sites More sharing options...
AdRock Posted 4April, 2019 Author Report Share Posted 4April, 2019 @ANF Ended up hearing from Colin at K-Jet Biz. He has a 090 body that he is going to build up for me. Reasonable price too. Thanks for the referral! One less reason for my car not to start once the engine is installed. Link to comment Share on other sites More sharing options...
ANF Posted 4April, 2019 Report Share Posted 4April, 2019 Glad my little bit of knowledge could help someone else!! The race is on (to see who has a running car first.... I think you are in front!) Link to comment Share on other sites More sharing options...
P-Kay Posted 4April, 2019 Report Share Posted 4April, 2019 16 minutes ago, ANF said: I think you are in front! by a country mile! Link to comment Share on other sites More sharing options...
ANF Posted 4April, 2019 Report Share Posted 4April, 2019 1 minute ago, P-Kay said: by a country mile! Oi!! That's enough out of you!! Jeez, some people..... Link to comment Share on other sites More sharing options...
AdRock Posted 4April, 2019 Author Report Share Posted 4April, 2019 15 minutes ago, P-Kay said: by a country mile! Still plenty of things I have to do! There was also some weeping of oil from the joins in the transmission, so I have to work out how to replace gaskets in a 915. There's another year right there. Link to comment Share on other sites More sharing options...
ANF Posted 4April, 2019 Report Share Posted 4April, 2019 Don't all air cooled Porsches weep oil... Easy fix!! Link to comment Share on other sites More sharing options...
AdRock Posted 4April, 2019 Author Report Share Posted 4April, 2019 Lol. I have the gasket set so might as well seal it up. Link to comment Share on other sites More sharing options...
