MFX Posted 7December, 2020 Author Report Share Posted 7December, 2020 This week I continue with the bonnet bulge I started last week, welding it all in and sorting dealing with the inevitable warping. tomo and 3legs 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12December, 2020 Author Report Share Posted 12December, 2020 This week I mange to finish up the bonnet bulge for the Alfarrari by adding back the under bonnet bracing that was removed. 3legs and tomo 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 19December, 2020 Author Report Share Posted 19December, 2020 This episode I move back inside the Alfarrari and work out what I am going to do to heat the cabin. 3legs and tomo 2 Quote Link to comment Share on other sites More sharing options...
Coastr Posted 20December, 2020 Report Share Posted 20December, 2020 Are you sure you need the 75mm piping? Most dash venting I have poked around is only 50mm or less and flows plenty of volume. Seeing as you’re restricting the outlets anyway I would have thought you could go to a smaller od pipe and still get away with it. Should be an off the shelf adapter for the marine pump. Compare the size of the 911 heat ducting for example. Seems like would take up less under dahs space and still give you the result. Quote Link to comment Share on other sites More sharing options...
MFX Posted 9January, 2021 Author Report Share Posted 9January, 2021 This week I start to tackle the rear end of the Alfarrari. 3legs 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 17January, 2021 Author Report Share Posted 17January, 2021 This week I finish the panhard rod conversion on the Alfarrari. Scott930, Carrera28 and 3legs 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 30January, 2021 Author Report Share Posted 30January, 2021 It has been a couple of weeks since I released a video on the Alfarrari. I have still been working just as hard on it but I have decided that moving forward I will only release a video when I have gotten enough work done. So here is the last couple of weeks work where I finally weld on the last of the panels to the shell. 3legs, tomo, firstone and 2 others 5 Quote Link to comment Share on other sites More sharing options...
MFX Posted 6February, 2021 Author Report Share Posted 6February, 2021 This week, I cover a bunch of different methods to make rust repair panels to fix up the swiss cheese door frames on the Alfarrari Scott930, tomo and 3legs 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 20February, 2021 Author Report Share Posted 20February, 2021 Back on the Alfarrari this week and it is time to tackle building the roll cage. tomo, JV911, LeeM and 2 others 4 1 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 23February, 2021 Report Share Posted 23February, 2021 Amazing how many "engineered street cars" are getting round with full cages (amongst other non legal things like bead-locks and drag radials) 🙄 MFX 1 Quote Link to comment Share on other sites More sharing options...
KGB Posted 23February, 2021 Report Share Posted 23February, 2021 Quando tu guida questa macchina? Spicciarsi! Quote Link to comment Share on other sites More sharing options...
michel Posted 23February, 2021 Report Share Posted 23February, 2021 35 minutes ago, JV911 said: Amazing how many "engineered street cars" are getting round with full cages (amongst other non legal things like bead-locks and drag radials) 🙄 I’ve been told and perhaps not for all states , incorporating the cage within the interior trim, allows it to be classed as integral to the car . Though door bars remain clearly non legal Quote Link to comment Share on other sites More sharing options...
MFX Posted 24February, 2021 Author Report Share Posted 24February, 2021 On 23/02/2021 at 22:06, michel said: I’ve been told and perhaps not for all states , incorporating the cage within the interior trim, allows it to be classed as integral to the car . Though door bars remain clearly non legal After going through the engineering process a couple of times, it seems like there is a way to get most things through if you want. I did think about trimming the cage in, but I have also been to too many motor vehicle accidents to take the risk. The argument is that it is hidden still means that the bars are much closer to your head than the original bodywork even though I am sure I could make it so that you never knew it was there if I wanted to. Unless I am wearing a harness and hans I would prefer not to drive a car with a front cage. Carrera28 and JV911 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 27February, 2021 Author Report Share Posted 27February, 2021 This week I button up the main structure of the Alfarrari's roll cage... mostly. tomo and firstone 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 13March, 2021 Author Report Share Posted 13March, 2021 This week I finish off the cage, measure up for a tailshaft and try out the Alfarrari's new wheels. GTP911, firstone, 3legs and 1 other 4 Quote Link to comment Share on other sites More sharing options...
3legs Posted 13March, 2021 Report Share Posted 13March, 2021 Love the wheels. MFX and SteveF 2 Quote Link to comment Share on other sites More sharing options...
st3ve Posted 13March, 2021 Report Share Posted 13March, 2021 Yep, wheels look spot on! 3legs and MFX 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 20March, 2021 Author Report Share Posted 20March, 2021 I am sure many of you last week were wondering how I was going to get those wheels to fit the Alfarrari, and this week we sort that out. LeeM, firstone, tomo and 2 others 5 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 20March, 2021 Report Share Posted 20March, 2021 I didn't see it or missed it but did you use a release wax or agent over the tape before glassing ? might remedy that pulling out issue that you have with the "captive nuts". Too late ?? Quote Link to comment Share on other sites More sharing options...
MFX Posted 20March, 2021 Author Report Share Posted 20March, 2021 1 hour ago, OZ930 said: I didn't see it or missed it but did you use a release wax or agent over the tape before glassing ? might remedy that pulling out issue that you have with the "captive nuts". Too late ?? No need for release with the tape. That part was fine. It was trying to unbolt them first that was the issue. Quote Link to comment Share on other sites More sharing options...
MFX Posted 28March, 2021 Author Report Share Posted 28March, 2021 This week I sort out the captive nut issue and finish flush fitting the flares to the Alfarrari. tomo, firstone and Scott930 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 3April, 2021 Author Report Share Posted 3April, 2021 This week I start sorting out my brake situation for the Alfarrari. tomo and 3legs 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 10April, 2021 Author Report Share Posted 10April, 2021 There have been many people questioning if the brakes on the Alfarrari would be able to cope with the Ferrari engines power. I think we now have that covered. 3legs, tomo and Troubleshooter 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 18April, 2021 Author Report Share Posted 18April, 2021 This week I have my first play with real CAD. I also tidy up the reservoirs from last week and have a look at tidying up the steering column. tomo and Scott930 2 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 18April, 2021 Report Share Posted 18April, 2021 On Saturday at the historic racing, I told an Alfa nut about this build and what engine you've fitted. The look on his face was priceless, and he said "A f@#$/^g WHAT??" 😂 MFX 1 Quote Link to comment Share on other sites More sharing options...
