911virgin Posted 29August, 2019 Report Share Posted 29August, 2019 hi all what are the common problems that one can expect with this 911 as it ages? Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 29August, 2019 Report Share Posted 29August, 2019 wallet getting lighter 🤣 Airhead, Dave997S, Troubleshooter and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
911virgin Posted 29August, 2019 Author Report Share Posted 29August, 2019 hahaha good one! very true though do you think they have more chance of future price appreciation than a 991.1 911? Quote Link to comment Share on other sites More sharing options...
Raven Posted 29August, 2019 Report Share Posted 29August, 2019 If its a manual Coupe ,,,,they appreciate very well over time ,,unless the market completely crash s you should not loose on one in the long term ...last of the air cooled era Autohaus has two lovely examples on offer at the moment .. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 29August, 2019 Report Share Posted 29August, 2019 Too late they are already aged! Specific 993 issues off the top of my head are: Engine oil leaks Lazy cam chain tensioners Kinematic rear suspension links AC evaporator holed - probably replaced already but 10 to 12 hour job otherwise Door check straps A pillar mounts Rust around the front and rear window openings under the trim Ballast resistors on the front condenser and oil cooler Spoiler control switch and curtain Dry bearing bushes in the HVAC fan motors Problems associated with the lack of use Sellers regret if you do sell it Harold996tt and YellowDieselGolf 2 Quote Link to comment Share on other sites More sharing options...
turboT Posted 29August, 2019 Report Share Posted 29August, 2019 1 hour ago, Raven said: If its a manual Coupe ,,,,they appreciate very well over time ,,unless the market completely crash s you should not loose on one in the long term ...last of the air cooled era is this true anymore? 993's appreciated, then depreciated 996's stopped getting cheaper, maybe, but haven't really appreciated that much. if you bought either of these (infact any porsche) now no one really knows the value, its just what you are prepared to pay. They certainly aren't going up in value anymore. Longterm - all we really know is what they cost to maintain/register etc. My experience with older cars is that you are typically spending at least $10k a year on them if your are honest with yourself. I don't see you getting this amount back in the car value increases anymore. Maybe not for some time, whilst every year you're still spending that $10k... The silver lining is that maybe we have reached the bottom? No more depreciation is still a good thing JWM and Peter M 2 Quote Link to comment Share on other sites More sharing options...
GC9911 Posted 29August, 2019 Report Share Posted 29August, 2019 25 minutes ago, Peter M said: Too late they are already aged! Specific 993 issues off the top of my head are: Engine oil leaks Lazy cam chain tensioners Kinematic rear suspension links AC evaporator holed - probably replaced already but 10 to 12 hour job otherwise Door check straps A pillar mounts Rust around the front and rear window openings under the trim Ballast resistors on the front condenser and oil cooler Spoiler control switch and curtain Dry bearing bushes in the HVAC fan motors Problems associated with the lack of use Sellers regret if you do sell it Thanks Peter for posting the short list. I think I’ve posted before, “Porsche” & “cheap” must never be used in the same sentence. Quote Link to comment Share on other sites More sharing options...
icu_jimmy Posted 29August, 2019 Report Share Posted 29August, 2019 I think if your buying for investment and value appreciation you might be better off investing in something else. Buy it to drive, and if it goes up in value, good stuff, but that’s a side benefit not the main game #getoutanddrive !! JWM, Gavn, LeeM and 2 others 5 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 29August, 2019 Report Share Posted 29August, 2019 Depends what you want it for. Driving on the weekends, comfortable daily driver, appreciating asset...??? I'm far from being any sort of expert on predicting the values of these cars, yet I honestly believe they won't go up again in this economy. In fact, I'd say they'll gradually decline in value unless a particular car is a pristine, desirable model. It's already gradually happening With some 993's being in the $100k mark or more, for the price of the silver 996.1 GT3 recently listed ($127k), I know where my money would go if I had any. GTP911 1 Quote Link to comment Share on other sites More sharing options...
Harold996tt Posted 29August, 2019 Report Share Posted 29August, 2019 20 hours ago, 911virgin said: hi all what are the common problems that one can expect with this 911 as it ages? Very little over time though PeterM has listed all the key ones that (may) befall you. If you get a well looked after one and depending on how much you drive it there may be little to worry about. The one with us the longest has been with us 20 years and it only needed the usual bottom valve covers changed and as previously mentioned rust under the front and rear windscreen fixed. But that car only now has 115k on the mileage. By comparison our 94 has had its gearbox rebuilt and bottom end work done on it... Granted because I wanted to put an RS pinion in the gear box and it became a... While we are in there.... But if you are unlucky then a top end rebuild as mileage approaches 200k is not unreasonable. And thst is big bucks. 14 hours ago, turboT said: is this true anymore? 993's appreciated, then depreciated 996's stopped getting cheaper, maybe, but haven't really appreciated that much. if you bought either of these (infact any porsche) now no one really knows the value, its just what you are prepared to pay. They certainly aren't going up in value anymore. Longterm - all we really know is what they cost to maintain/register etc. My experience with older cars is that you are typically spending at least $10k a year on them if your are honest with yourself. I don't see you getting this amount back in the car value increases anymore. Maybe not for some time, whilst every year you're still spending that $10k... The silver lining is that maybe we have reached the bottom? No more depreciation is still a good thing General 993 prices are definitely down selling for less than the 964 as far as I can see... Boy how times change. I remember when the 993 was the king sigh. But the 993S that the poster is looking at based off his post title is a bit unusual. Less than 30 manual wide body two wheel drive cars were imported into Australia new and they still (rightfully or wrongfully) command a premium. Added to the fact the Carrera S wide body two wheel drive was literally the last of the air cooled cars ever to come out of the factory when they were trying to find a way to market the left over turbo body shells means thst for those in the know these cars will still command a premium... Particularly in manual version. Last one sold 7 months back for around 230k. They definitely paid on the high side as far as I am concerned but it is what it is. For the rarer cars the sellers won't budge and the buyer who is looking specifically for an S in manual knows why they want that specific car. The tip version of the same car absurdly sells for 100k less.... Having said that no car makes sense as an investment once storage and maintenance costs come into play. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 29August, 2019 Report Share Posted 29August, 2019 9 minutes ago, Harold996tt said: Very little over time though PeterM has listed all the big ones. Yes, to clarify you would be very unlucky to find a car that has suffered ALL of those issues but they all will suffer at least 2/3's of that list. Not really a big deal to put right except the last listed one. I still suffer seller's regret possibly weekly...…. Harold996tt 1 Quote Link to comment Share on other sites More sharing options...
911virgin Posted 30August, 2019 Author Report Share Posted 30August, 2019 thanks for all the valuable input people very useful! I would be looking for an automatic 993 S (for the wife to drive too) i have been tracking 993 sales and in 2015 a 993 S black with approx. 90000kms sold for $90k ( at cityautomobiles), last year same car was on carsales , now up to 140000kms(private seller) asking $140k for over 12 months- i don't know if it sold but the sellers ad ceased . there was a sale of an arena red 993 s tip, around 2018 for approx$150k, maybe a few grand less, this was orig sold by Porsche Doncaster in 2015, then up on carsales (private seller in Adelaide) then sold in 2018 in Melb, around 60000kms from memory. a vic private seller sold a zenith blue 993 C tip 2018 for around $160k, 106000kms, this has been unsold on carsales (private seller NSW) for the last 8 months or so, initial ask $166k, now $160k, 109000kms. i believe this car was sold at duttons circa 2016 what do you think a 993 S tip is worth today? Quote Link to comment Share on other sites More sharing options...
Harold996tt Posted 30August, 2019 Report Share Posted 30August, 2019 4 hours ago, 911virgin said: thanks for all the valuable input people very useful! I would be looking for an automatic 993 S (for the wife to drive too) i have been tracking 993 sales and in 2015 a 993 S black with approx. 90000kms sold for $90k ( at cityautomobiles), last year same car was on carsales , now up to 140000kms(private seller) asking $140k for over 12 months- i don't know if it sold but the sellers ad ceased . there was a sale of an arena red 993 s tip, around 2018 for approx$150k, maybe a few grand less, this was orig sold by Porsche Doncaster in 2015, then up on carsales (private seller in Adelaide) then sold in 2018 in Melb, around 60000kms from memory. a vic private seller sold a zenith blue 993 C tip 2018 for around $160k, 106000kms, this has been unsold on carsales (private seller NSW) for the last 8 months or so, initial ask $166k, now $160k, 109000kms. i believe this car was sold at duttons circa 2016 what do you think a 993 S tip is worth today? Tips are definitely not easy sells and as mentioned, they historically sold for around 100k less than the manual version in wide body S models. But I have no verified actual closed deals on tips recently unfortunately. Like you I have only in the last 12 months seen the ads on those in the last 12 months but with no verified completed sales... Quote Link to comment Share on other sites More sharing options...
