Hi beam blues
Captoz
I got the high beam blues. Stalk switch only operates hi beam. Have to hold the stalk in for low beam, also have no hi beam blue light showing. Relay problem? Any ideas people?
cheers jay
It's the contacts in the hi/lo switch and a very common issue.  If you google it you'll get the good oil on the fix from Pelican.  Also PFA'er Merv posted about the same issue a few weeks ago
Yep. But mine is the opposite.  No HB, unless I hold the stalk in flash mode.  Have bought a new module to see if that does the trick.  Spent some hours trying to repair the existing one. Cleaned and aligned the terminals and all good on the multimeter, but no change.
Thanks guys. Followed the instructions on the Pelican board. Problem fixed. Now whats the next little thing to fix.....
Cheers
J
