MFX Posted 4March, 2020 Report Share Posted 4March, 2020 This week Harry has had to go onto the back burner, because Archie needs a new clutch and on a 996, that means IMS and RMS while I am there. Rod C, WOKA, 3legs and 6 others 8 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 8March, 2020 Author Report Share Posted 8March, 2020 In this episode I attempt to replace the infamous IMS bearing in Archie. 3legs, WOKA, DT and 2 others 5 Quote Link to comment Share on other sites More sharing options...
3legs Posted 8March, 2020 Report Share Posted 8March, 2020 Now I know why it cost so much to replace a bearing.😲 MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 8March, 2020 Author Report Share Posted 8March, 2020 3 minutes ago, 3legs said: Now I know why it cost so much to replace a bearing.😲 The replacement bearing itself is still over $1k which is a crazy price for something that is really a $30 bearing, but the labour is a lot. 3legs 1 Quote Link to comment Share on other sites More sharing options...
Stephen Tinker Posted 8March, 2020 Report Share Posted 8March, 2020 Hey Jeff - a quick question... Before trying to remove the bearing, you punched the slotted centre retaining bolt through into the IMS shaft - how did you pull it back into the bearing? I was under the impression that once the bolt was "floating loose" in hollow shaft you wouldn't be able to fish it out again.... I believe its the steel retaining spring stopping the bearing from being pulled out - it goes with quite a loud snap when using the (expensive) puller supplied by LN Engineering. MFX and GC9911 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 10March, 2020 Author Report Share Posted 10March, 2020 In this episode I replace the rear main seal and the clutch on Archie 996, and button it all back up. Hopefully it will run! On 08/03/2020 at 17:42, Stephen Tinker said: Hey Jeff - a quick question... Before trying to remove the bearing, you punched the slotted centre retaining bolt through into the IMS shaft - how did you pull it back into the bearing? I was under the impression that once the bolt was "floating loose" in hollow shaft you wouldn't be able to fish it out again.... I believe its the steel retaining spring stopping the bearing from being pulled out - it goes with quite a loud snap when using the (expensive) puller supplied by LN Engineering. It was actually quite easy to get the bolt back in with a magnet. That was probably the easiest part of the whole thing tomo, DT and firstone 3 Quote Link to comment Share on other sites More sharing options...
