911 Posted 21February, 2021 Report Share Posted 21February, 2021 I just purchased the Ctek 5. Is it ok to leave it plugged in all the time? Or do some of you periodically disconnect it. Even when the car is not in use I've also noticed that the connector is too small for my battery bolt. Has anyone modified it? Thinking whether I should drill the hole bigger or just cut it and open the ring. Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 21February, 2021 Report Share Posted 21February, 2021 10 minutes ago, wangan said: Is it ok to leave it plugged in Mine are and yes, you need to modify to suit the bolt - Happy battery maintaining 911 1 Quote Link to comment Share on other sites More sharing options...
Stepo Posted 22February, 2021 Report Share Posted 22February, 2021 2 hours ago, wangan said: I just purchased the Ctek 5. Is it ok to leave it plugged in all the time? Or do some of you periodically disconnect it. Even when the car is not in use I've also noticed that the connector is too small for my battery bolt. Has anyone modified it? Thinking whether I should drill the hole bigger or just cut it and open the ring. I also leave mine plugged in as they just cycle through and monitor when no charging is required. Take care if you drill the hole bigger as the material is thin and the drill bit may grab and rip the ring apart if too much pressure is applied. An older drill bit may be more forgiving, there isn't much to hold onto, I was successful with one unit and ripped the other, had to recrimp a new eyelet. Maybe try opening up with a round file slowly. 911 1 Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 22February, 2021 Report Share Posted 22February, 2021 7 hours ago, wangan said: I just purchased the Ctek 5. Is it ok to leave it plugged in all the time? Or do some of you periodically disconnect it. Even when the car is not in use I've also noticed that the connector is too small for my battery bolt. Has anyone modified it? Thinking whether I should drill the hole bigger or just cut it and open the ring. Yep .. fine to leave plugged in all the time .. just don't forget to disconnect it when you go for a drive! .. 😅 In terms of the eyelets ... just snip them off and crimp on some new ones. Done. 911 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted 22February, 2021 Report Share Posted 22February, 2021 you can buy a CTEK part with bigger connectors if you don't want to modify your own. I think it's M10 vs M8 Quote Link to comment Share on other sites More sharing options...
Grimmy Posted 22February, 2021 Report Share Posted 22February, 2021 Be aware that if it is a modern model with a battery monitoring circuit it is not recommended to connect directly to the NEGATIVE terminal. There is a post that is specifically assigned for the connection. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 22February, 2021 Report Share Posted 22February, 2021 7 hours ago, Stepo said: Take care if you drill the hole bigger as the material is thin and the drill bit may grab and rip the ring apart if too much pressure is applied. An older drill bit may be more forgiving, there isn't much to hold onto, I was successful with one unit and ripped the other, had to recrimp a new eyelet. Maybe try opening up with a round file slowly. wagan, Use a pair of pliers to hold one side of the connector with if flat on a piece of wood as you drill it. No harm can occur to you then. Quote Link to comment Share on other sites More sharing options...
911 Posted 22February, 2021 Report Share Posted 22February, 2021 3 hours ago, Russ said: you can buy a CTEK part with bigger connectors if you don't want to modify your own. I think it's M10 vs M8 Thanks @Russ, I'll take a look. 2 hours ago, Grimmy said: Be aware that if it is a modern model with a battery monitoring circuit it is not recommended to connect directly to the NEGATIVE terminal. There is a post that is specifically assigned for the connection. It's 3.2 with a Bond ultimate battery. I thought, the neg terminal on the battery was fine. If anyone can confirm? 44 minutes ago, Peter M said: wagan, Use a pair of pliers to hold one side of the connector with if flat on a piece of wood as you drill it. No harm can occur to you then. Thanks @Peter. I'll give it a go tomorrow at work. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 22February, 2021 Report Share Posted 22February, 2021 1 hour ago, wangan said: It's 3.2 with a Bond ultimate battery. I thought, the neg terminal on the battery was fine. If anyone can confirm? . No problem with connecting directly to the battery terminals. Just suggest the charger is off when you do it so there is no risk of a spark igniting any vented hydrogen. I suspect manufacturers now provide an earthing point away from the battery for jump starting to avoid this risk. tomo 1 Quote Link to comment Share on other sites More sharing options...
911 Posted 24February, 2021 Report Share Posted 24February, 2021 Thanks for the reply @Peter M Is there a better place to mount the negative eyelet from the trickle charger, or just directly to the battery clamp? Manual states: Connect the black clamp to the vehicle chassis remote from the fuel pipe and the battery. Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 24February, 2021 Report Share Posted 24February, 2021 Mine are direct to the battery Quote Link to comment Share on other sites More sharing options...
Peter M Posted 24February, 2021 Report Share Posted 24February, 2021 wangan, I'm assuming you are using this harness: Quote Link to comment Share on other sites More sharing options...
911 Posted 24February, 2021 Report Share Posted 24February, 2021 1 minute ago, Peter M said: wangan, I'm assuming you are using this harness: That's the one @Peter M Quote Link to comment Share on other sites More sharing options...
Peter M Posted 24February, 2021 Report Share Posted 24February, 2021 If so these are designed to have the eyelets connect directly to the existing battery clamps. In terms of safety, the charger plugs into the harness socket away from battery and the risk of collected hydrogen. The Ctek's also have an antisparking feature too so even if you forget to turn the charger off before your reconnect, you're doubly safe! Stepo 1 Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 24February, 2021 Report Share Posted 24February, 2021 Mine is connected directly to the clamps. Has been for months. I also have similar to the above photo but mine has the “traffic light” system built in. I tend to connect the harness in first then plug it in ... Quote Link to comment Share on other sites More sharing options...
911virgin Posted 3March, 2021 Report Share Posted 3March, 2021 do 993's have the cigarette lighter plug in option for a CTEK battery charger? Quote Link to comment Share on other sites More sharing options...
tomo Posted 12April, 2021 Report Share Posted 12April, 2021 Repco have a specials on the C Tek chargers again, Scored a 12v 10 amp was 275$ paid 188$ :). Quote Link to comment Share on other sites More sharing options...
tomo Posted 12April, 2021 Report Share Posted 12April, 2021 On 03/03/2021 at 15:23, 911virgin said: do 993's have the cigarette lighter plug in option for a CTEK battery charger? If the 993 has a cigarette lighter socket it should work in theory, But an Auto Elec tech would be able to give you a more confident answer. Quote Link to comment Share on other sites More sharing options...
LeeM Posted 16April, 2021 Report Share Posted 16April, 2021 30 minutes ago, tomo said: Just wondering has any one changed their leather color successfully, If so what is the best product? Thanks Right thread Tomo? 😅 Quote Link to comment Share on other sites More sharing options...
tomo Posted 16April, 2021 Report Share Posted 16April, 2021 30 minutes ago, LeeM said: Right thread Tomo? 😅 Doh ! LeeM 1 Quote Link to comment Share on other sites More sharing options...
