privatepang Posted 4April, 2020 Report Share Posted 4April, 2020 Hey guys, so clutch was slipping really badly and ended up having to split the 915 trans from the engine. Trans (rebuilt unit not long ago..) is leaking thru the input shaft area and saturated my clutch and pressure plate. Clutch otherwise has minimal wear. I've done maybe 2000kms on it. Curious if this means I need to replace it due to the oil contamination ? Quote Link to comment Share on other sites More sharing options...
Raven Posted 4April, 2020 Report Share Posted 4April, 2020 On the safe side replace the friction plate disc of the clutch ,had a friend who had a same issue with gearbox oil leak contaminating the friction plate material .. He cleaned up the disc material with degreaser and chemical cleaners prior to re instillation thinking that it would be ok ,but ended up having to remove the gearbox again and replace the friction disc as the clutch keep slipping at higher RPM due to the oil contamination in the disc friction material . In his case it would have been less of a headache to spend the $$$ and replace the friction Disc first up .. firstone 1 Quote Link to comment Share on other sites More sharing options...
9er Posted 4April, 2020 Report Share Posted 4April, 2020 Unfortunately as good a job you do cleaning it, heat and pressure from use will bring out more contaminant to the clutch Surface. At least the plate itself is not expensive to replace. Quote Link to comment Share on other sites More sharing options...
privatepang Posted 4April, 2020 Author Report Share Posted 4April, 2020 I ended buying a new clutch plus plate anyways thinking it was stuffed but guess wondered if it was worth keeping it for later. Looks like best to just replace the whole lot. Thanks guys Raven 1 Quote Link to comment Share on other sites More sharing options...
Raven Posted 5April, 2020 Report Share Posted 5April, 2020 some times these things just are not worth the headache ,,,you have spent the money wisely instal everything and have trouble free driving for years to come "Peace of Mind" firstone 1 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 5April, 2020 Report Share Posted 5April, 2020 In the olden days you could pour methylated spirits over the plate (or brake shoes) then light it. This would draw out the oil or brake fluid, then lightly sand the plate (or shoe). Worked a treat. Of course, these were the days of riveted asbestos pads.....😧 Quote Link to comment Share on other sites More sharing options...
Skidmarks Posted 5April, 2020 Report Share Posted 5April, 2020 I had this happen on my IROC. I use a standard 930 pressure plate and puck clutch. It takes 410 hp. We cleaned it up and it works just fine. Quote Link to comment Share on other sites More sharing options...
Airhead Posted 5April, 2020 Report Share Posted 5April, 2020 8 hours ago, OZ930 said: In the olden days you could pour methylated spirits over the plate (or brake shoes) then light it. This would draw out the oil or brake fluid, then lightly sand the plate (or shoe). Worked a treat. Of course, these were the days of riveted asbestos pads.....😧 It's a wonder you're here to tell the tale. Asbestos not good for you apparently. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 5April, 2020 Report Share Posted 5April, 2020 20 hours ago, OZ930 said: In the olden days you could pour methylated spirits over the plate (or brake shoes) then light it. This would draw out the oil or brake fluid, then lightly sand the plate (or shoe). LOL, I'd forgotten doing that! Quote Link to comment Share on other sites More sharing options...
privatepang Posted 16June, 2020 Author Report Share Posted 16June, 2020 So hoping for some ideas here. Ended getting the car back and we've been trying to diagnose this sizeable oil leak which always appears near the omega spring area and where the gearbox meets the engine. Had a look at the engine bay and noticed it was wet around the triangle of death area so replaced all the thermastat seals, o ring seal and the oil pressure switch and now the top is dry but the same area underneath remains super oily. I read on PP that people have had similar issues and it was because the flywheel seal was installed backwards and the due to the triangle of death. When we replaced the clutch , we didnt touch the flywheel seal and it definitely wasnt leaking like this prior to splitting the engine and tranny.... We did remove the flywheel and pressure plate to inspect for damage but that was about it. Any other ideas of where this could be coming from? Definitely seems like engine oil and not gearbox oil. Checked all the oil lines that i can see from the bottom of the car and they are all dry.... engine bay seems dry now as well after we changed the triangle of death seals + switch....last resort is to drop the engine again but trying to avoid that if possible.. Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 16June, 2020 Report Share Posted 16June, 2020 Front seal in the gearbox Quote Link to comment Share on other sites More sharing options...
privatepang Posted 16June, 2020 Author Report Share Posted 16June, 2020 9 hours ago, OZ930 said: Front seal in the gearbox But it seems like engine oil? Quote Link to comment Share on other sites More sharing options...
Zelrik911 Posted 16June, 2020 Report Share Posted 16June, 2020 30 minutes ago, privatepang said: But it seems like engine oil? perhaps its the engine Oil radiator/cooler leaking (perhaps only a seal if your lucky). All the 911's of this time eventually had leaks in their radiators. Quote Link to comment Share on other sites More sharing options...
privatepang Posted 17June, 2020 Author Report Share Posted 17June, 2020 From doing more searches, it may be the rear main seal... doh that would require dropping the engine again.. We did remove the flywheel to get it machined so this sort of makes sense. Not sure what other seals i really should change whilst we do it. Input shaft seal already done.. Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 18June, 2020 Report Share Posted 18June, 2020 when you removed the flywheel, did you see oil leaks around the rear main seal? Or did you think that oil was from the top that had leaked down? Has your seal started walking out of the case? Merv 1 Quote Link to comment Share on other sites More sharing options...
