Nitrogen tyre fill Yes/No
CarreraG50
Hi All,
Car is booked in next week for four new RE003's, the shop has recommended a nitrogen fill @ $9.90 a tyre,
apparently more stable pressures as they heat up, as well as less loss when the car is sitting (which it does a lot).
I have a compressor, so maintaining pressure isn't a big deal, what do you think Yes or No
TIA
John
1 hour ago, CarreraG50 said:
Hi All,
TIA
John
I'm assuming 16", not 15"?  15" is probably non-existent. I haven't searched for replacements for my 15" x 7" and 8" Fuchs for a while as I gave up last time.
Unless you are racing or doing sustained high speeds ,,,,it is not worth it ....I just keep my tire pressures at the recommended psi for my spirited road use on my 997 ...
I dont even use nitrogen  on my dedicated track car ,,,,I work with the 5 psi difference from cold tire to Hot tire pressure ...
