Lucky Phil Posted 17May, 2020 Report Share Posted 17May, 2020 Can anyone recommend a product to use on a vinyl roof. The roof is in good condition as car is always garaged. I read somewhere once that best just to hose it and never use soap or pressure spray which I always abide by, but wondering if a vinyl protector will give it that extra protection and allow water to bead. It just sits flat on the roof at the moment when I hose it. Any suggestions what to do or not to do and what product, if any, to use? Thanks Phil Quote Link to comment Share on other sites More sharing options...
JB Posted 17May, 2020 Report Share Posted 17May, 2020 3 hours ago, Lucky Phil said: Can anyone recommend a product to use on a vinyl roof. The roof is in good condition as car is always garaged. I read somewhere once that best just to hose it and never use soap or pressure spray which I always abide by, but wondering if a vinyl protector will give it that extra protection and allow water to bead. It just sits flat on the roof at the moment when I hose it. Any suggestions what to do or not to do and what product, if any, to use? Thanks Phil Phil, zero chemicals, high pressure to only spot clean on a non direct angle. personally I would a ceramic coat across it. cheers Quote Link to comment Share on other sites More sharing options...
Raven Posted 17May, 2020 Report Share Posted 17May, 2020 Mate there are a lot of products out there in the market that claim to add protection to Vinyl roof and Vinyl surfaces ... The issue I have with these is if you start using them you have to keep using them or you end up with cracks and damage .. Sometimes I think these sorts of products actually do more harm than good ,,,always a tough one and every brand claims to be better than the other in some way .... Quote Link to comment Share on other sites More sharing options...
