Aluminium sun visor clip for 911, 912, 914, 944, 964 & 993
After years of use and having been baked by UV rays, the original plastic sun visor clips fitted to many classic Porsches can crack, allowing the visors to flap around freely.
As a more permanent solution than a simple exchange part, we have stocked up on these replacements which are engineered with aluminium bodies, replacing the plastic.
Still featuring the polished steel pin that slides into to the sun visor, the body of the clip takes the OE form, but finished in black powder coat rather than plain plastic.
Stronger, unaffected by UV and more durable in extremes of temperature, it is the perfect upgrade for this small but essential component. Priced each at  AUS $43.95 for Cabriolet and Targa models and AUS $84.15 each for the more complicated curved pin type as found in the coupe, they all come covered with a lifetime warranty by the manufacturer.
They can be bought from the following links;
Coupe Sun Visor Bracket
Targa/Cabrio Sun Visor Mounting
