Cheshire Cat Posted 7June, 2020 Report Share Posted 7June, 2020 Well. a while ago I was interested in a new clutch kit/disk+bearing for my "project" and I realized that with everyone`s favorite Sachs it is a bit tricky. Basically how I see this things - we have: 1. Basic Sachs clutch kit (pressure plate + disk + bearing) - 721.75 USD (at pelicanparts) 2. Sachs Power clutch (basically the same as above but aluminium pressure plate instead the cast iron one) - 898.25 USD (same source) 3. Mysterious Sachs Performance kit which consist of some kind of pressure plate and disk - 804.33 euro (from sachs performance official website minus VAT) Did I miss something? Quote Link to comment Share on other sites More sharing options...
Paul Carrera Posted 7June, 2020 Report Share Posted 7June, 2020 I changed to the power clutch kit and it made a huge difference, the car revs so much easier than the standard. After researching the lightened flywheel option I decided it wasn’t really that suitable for street use Quote Link to comment Share on other sites More sharing options...
81SC Posted 7June, 2020 Report Share Posted 7June, 2020 No affiliation, check out Heritage Parts Centre from England. Their prices seem competitive compared to the usual USA suppliers. I’ve been looking at their stuff since one of their guys posted on this site. https://www.heritagepartscentre.com/au/91511691100-clutch-kit.html Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 7June, 2020 Author Report Share Posted 7June, 2020 1 hour ago, 81SC said: No affiliation, check out Heritage Parts Centre from England. Their prices seem competitive compared to the usual USA suppliers. I’ve been looking at their stuff since one of their guys posted on this site. https://www.heritagepartscentre.com/au/91511691100-clutch-kit.html Really good price. Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 7June, 2020 Report Share Posted 7June, 2020 I know this isn't what you were asking, but I have been buying my clutch kits from James at Autohaus.. really competitive when you included overseas shipping and conversion rates. Merv 1 Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 8June, 2020 Author Report Share Posted 8June, 2020 2 hours ago, Mike D'Silva said: I know this isn't what you were asking, but I have been buying my clutch kits from James at Autohaus.. really competitive when you included overseas shipping and conversion rates. Yeah not really, but thank you, it`s good to know. Apparently I have an access to a very good parts source with pretty good prices. Tried to figure things with the clutch kits to start with Quote Link to comment Share on other sites More sharing options...
Merv Posted 8June, 2020 Report Share Posted 8June, 2020 I never buy from the US anymore and prefer Autohaus Hamilton or BWA. Quote Link to comment Share on other sites More sharing options...
smit2100 Posted 8June, 2020 Report Share Posted 8June, 2020 On 07/06/2020 at 14:45, Cheshire Cat said: Well. a while ago I was interested in a new clutch kit/disk+bearing for my "project" and I realized that with everyone`s favorite Sachs it is a bit tricky. Basically how I see this things - we have: 1. Basic Sachs clutch kit (pressure plate + disk + bearing) - 721.75 USD (at pelicanparts) 2. Sachs Power clutch (basically the same as above but aluminium pressure plate instead the cast iron one) - 898.25 USD (same source) 3. Mysterious Sachs Performance kit which consist of some kind of pressure plate and disk - 804.33 euro (from sachs performance official website minus VAT) Did I miss something? A different P car (996) compared to your project, but for me, favourite Sachs depends on your" project" and primarily how much torque you expect to be pumping out and can the clutch pressure plate hold the torque. Below is the list of clutch parts for my project. The clutch kit I chose was based around a Sachs pressure plate that can hold up to 890nm of torque on paper. All the other part numbers (second column ) are Porsche factory clutch part numbers spanning aircoooled and watercooled era's for my project. The part numbers not in bold, were purchased as part of a clutch kit. The rest of the parts are preventative maintenance, i.e. engine / gearbox dropped why not replace those parts getting closer to 20 years old in my case. Re: Kit 1 vs Kit2 above, when you say basically the same, not convinced. I would expect Kit 2 is rated to hold more torque than kit 1 as well as shedding a little bit of weight. Can't you look up the sach's part number (generally start with an 8) , in the kit and drill down on the specs, noting torque rating and that's probabaly driving the price differentials. Clutch Master Cyclinder#1 99642317152 Circlip pressure Line#1a 99642361400 Cyclinder Bolt#1b 99642331506 Cyclinder safety clip for bolt#1c 99916602201 Hose clamp#9 99951253200 Moulded Hose#10 99742334451 Seal Ring#13 99970740340 Clutch Hose#15 99642337754 Hose clamp#17 99951255400 Hexagon Bolt #20 90037802901 Pentosin Fluid - 1000ML 00004330574 Pressure Accumulator 99731416600 Pressure Accumulator seal ring 99970722440 Sachs 764 clutch pressure plate (88.3082.999.764) 883082999764 997GT3RS 4.0 clutch disc 99711601391 964 LWFW 96410223931 Flywheel bolts 92810215101 Pilot bearing 93110211100 Throwout bearing 94411608001 Guide tube #3 95011681330 Guide tube bolts #4 99927007001 Ring gear 96411414331 Pressure plate bolts 99951001502 Cross shaft for release bearing fork#5 95011671004 Gasket 13,02 x 16.4 #6 99911341840 Articulated Bush #7 99920133901 Cover #8 95011672500 Articulated Bush #9 99920136501 Retaining bracket #10 95011671302 Heaxagon Head Bolt M6X16 #11 90007505703 Shaft Bush#12 95011671501 Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 8June, 2020 Author Report Share Posted 8June, 2020 23 minutes ago, smit2100 said: Re: Kit 1 vs Kit2 above, when you say basically the same, not convinced. I would expect Kit 2 is rated to hold more torque than kit 1 as well as shedding a little bit of weight. Can't you look up the sach's part number (generally start with an 😎 , in the kit and drill down on the specs, noting torque rating and that's probabaly driving the price differentials. Well, that actually is the thing. When I was looking for this sort of information I stumbled pretty hard. I can`t find any torque capabilities of named kits whatsoever. The things I know for sure - the "normal" kit comes in parts, so you can order either the disk or the pp or bearing or all together, the "power clutch" kit comes only as a kit. But neither of those have any torque numbers. On the other hand the Sachs Performance clutch kit names the torque handling - 420 Nm or so don`t remember. In my case I have a disk from an aftermarket clutch company named Action Clutch (6 puck sprung handling about 400+ Nm) so, we shall see... Quote Link to comment Share on other sites More sharing options...
smit2100 Posted 8June, 2020 Report Share Posted 8June, 2020 47 minutes ago, Cheshire Cat said: Well, that actually is the thing. When I was looking for this sort of information I stumbled pretty hard. I can`t find any torque capabilities of named kits whatsoever. The things I know for sure - the "normal" kit comes in parts, so you can order either the disk or the pp or bearing or all together, the "power clutch" kit comes only as a kit. But neither of those have any torque numbers. On the other hand the Sachs Performance clutch kit names the torque handling - 420 Nm or so don`t remember. In my case I have a disk from an aftermarket clutch company named Action Clutch (6 puck sprung handling about 400+ Nm) so, we shall see... https://www.design911.com/Porsche/911-1965-1989/911-1974-83/Clutch-Kits--High-Performance/pt376_938_-cma81-cmo104-ct359/ Not sure what aircooled you have, but there are some tq numbers on this site with some sachs kits Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 8June, 2020 Author Report Share Posted 8June, 2020 5 minutes ago, smit2100 said: https://www.design911.com/Porsche/911-1965-1989/911-1974-83/Clutch-Kits--High-Performance/pt376_938_-cma81-cmo104-ct359/ Not sure what aircooled you have, but there are some tq numbers on this site with some sachs kits yep, my bad, it`s 350 (and 320) Nm not 420 and it`s sachs performance, which is taken from here https://www.sachsperformance.com/en/clutch-kit/performance-clutch-sachs/porsche-911/3-0-sc-carrera-154kw Quote Link to comment Share on other sites More sharing options...
Merv Posted 8June, 2020 Report Share Posted 8June, 2020 I am not sure which car you have with which mods but if a stock fitting, I would call James at Autohaus and give him your VIN and he will specify the exact parts you need. It can be a shot in the dark otherwise. Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 9June, 2020 Author Report Share Posted 9June, 2020 2 hours ago, Merv said: I am not sure which car you have with which mods but if a stock fitting, I would call James at Autohaus and give him your VIN and he will specify the exact parts you need. It can be a shot in the dark otherwise. Yeah nah, I'm all sorted, as mentioned before. I was trying to figure a few detail about the kits, but seems like not so many people digging into this that deep. Quote Link to comment Share on other sites More sharing options...
SM911 Posted 23June, 2020 Report Share Posted 23June, 2020 On 08/06/2020 at 18:06, Merv said: I never buy from the US anymore and prefer Autohaus Hamilton or BWA. Same for me... Quote Link to comment Share on other sites More sharing options...
