Dave997S Posted 24June, 2020 Report Share Posted 24June, 2020 Mr Brennan advised me I’ll need new engine mounts at the next service and wondering what the brainstrust think about what I replace the OEMs with. Driving is weekend driving only and if I did track work it’d be rare, so I’m not after track taughtness. Should I stick with OEM or a semi-solid set up? Keen to hear about what others have done and thoughts on the differences and changes in feel etc Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 24June, 2020 Report Share Posted 24June, 2020 OEM I would think given your intended use Dave, semi solids are reported to transfer more vibration and engine noise to the cabin. I'd take David's recommendation... Dave997S and tomo 2 Quote Link to comment Share on other sites More sharing options...
Stephen Tinker Posted 24June, 2020 Report Share Posted 24June, 2020 ^^^^ as THT says ^^^ I looked into this a few weeks ago - there is a big difference in construction between the Porsche mounts (fluid filled) and aftermarket (rubber composite). It seems you pay a lot of $$ for just rubber block mounts.... Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 24June, 2020 Author Report Share Posted 24June, 2020 10 hours ago, TwoHeadsTas said: OEM I would think given your intended use Dave, semi solids are reported to transfer more vibration and engine noise to the cabin. I'd take David's recommendation... If I did go semi solids they'd be the softest setting, my weekend driving is "spirited". Mr Brennan is fitting some new rollers soon so I'll ask what he thinks. 3 minutes ago, Stephen Tinker said: ^^^^ as THT says ^^^ I looked into this a few weeks ago - there is a big difference in construction between the Porsche mounts (fluid filled) and aftermarket (rubber composite). It seems you pay a lot of $$ for just rubber block mounts.... Did you look at the rennline ones? I have seen a couple of YouTube vids and they'd be what I was thinking of getting Quote Link to comment Share on other sites More sharing options...
Stephen Tinker Posted 25June, 2020 Report Share Posted 25June, 2020 Yes - there are a few mounts available out of the US - not all are long lasting either - do a search on Rennlist for lots of reading. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
PDean Posted 25June, 2020 Report Share Posted 25June, 2020 Mr Brennan replaced mine last year, I took his recommendation on using OEM. 👍 Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 25June, 2020 Report Share Posted 25June, 2020 Check out Prekom in Slovenia. Great prices and excellent products. Reportedly they supply the Rennline ones, which are then marked up. They have various shore rubber ones from OEM to much harder. I got some for my motor and tranny on the 3.2. Excellent quality. Dave997S and Raven 2 Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 25June, 2020 Author Report Share Posted 25June, 2020 I did see a brand called Function First which take an OEM mount and then add bushing in the void (?) to give the (supposed) best of both worlds. A few nice comments on forums about them too. Quote Link to comment Share on other sites More sharing options...
StevepGT3 Posted 26June, 2020 Report Share Posted 26June, 2020 56 minutes ago, Dave986 said: I did see a brand called Function First which take an OEM mount and then add bushing in the void (?) to give the (supposed) best of both worlds. A few nice comments on forums about them too. Tried them in my 993 and pulled them out after one drive, added too much NVH for my liking, with zero noticeable benefit ,if you wear your baseball cap backwards you might think they are fully sick Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 26June, 2020 Author Report Share Posted 26June, 2020 3 minutes ago, StevepGT3 said: Tried them in my 993 and pulled them out after one drive, added too much NVH for my liking, with zero noticeable benefit ,if you wear your baseball cap backwards you might think they are fully sick Thanks for the tip Steve. My caps are worn the correct way. Merv 1 Quote Link to comment Share on other sites More sharing options...
StevepGT3 Posted 26June, 2020 Report Share Posted 26June, 2020 Just now, Dave986 said: Thanks for the tip Steve. My caps are worn the correct way. Well stick to OEM then. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 26June, 2020 Report Share Posted 26June, 2020 Mostly the best choice. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 27June, 2020 Report Share Posted 27June, 2020 I have genuine 964 RS mounts (semi solid) in my 996 - highly recommended if you do any SMT like driving. I haven't found any added NHV. If you just do regular driving I would stick with OEM Dave997S 1 Quote Link to comment Share on other sites More sharing options...
