Jason E Posted 27July, 2020 Report Share Posted 27July, 2020 My 944S2 is now on its way to a new owner & all my accumulated parts need to find new homes as well. At least half are new genuine parts, unopened & still in original packaging from either Porsche Centre Brisbane, Pelican Parts, Paragon or similar OEM resellers etc. Many of the used parts are in excellent condition & some are "normal" condition used parts I have acquired over the last 4 years. Happy to provide further info or photos by PM, email or text to interested inquirers. Can definitely post parts to you for better than standard Auspost rates. I have based prices either on near what I paid or on what ebay or other resellers are asking. I will supply photos of parts & part numbers so you can see what you are getting on request. Located Brisbane, Northside. 0410439764 ....................................................................................... Interior 3/4 trim panel (x2 left & right side) with speaker & speaker cover (for 85.5 to 91). Used but in outstanding condition. Marine Blue. $570. Interior arm rest/ door handles (x2 left & right side) excellent condition, Maine Blue. $200. Sunroof interior trim panel, excellent condition (tiny defect - photos supplied.) Marine Blue $200. Sunroof interior sacrificial plastic trim clips (required to secure interior trim panel to the exterior panel) - new from PCB - $3.00 each - I have 15. Sunroof hinge latch mount (924/944/968) 477 871 219 - $10 Hatch area Light switch/ Cover. Used but in excellent condition - $20. Handbrake interior handle - Marine Blue - reasonable condition - $50. Wheel nuts x 24 - reasonable - $40. 968 genuine Cup wheel set (4) 16 inch (staggered 7s & 8s). $999.00 - good condition. Not refurbished. D90 wheels 16inch x 2 (these are front 6 inch width wheels ET52 for a 993) - straight, reasonable condition - $100 for the pair. Mirror housing & motors x 3. Varying conditions from very good to reasonable. from $50 Dash (oval) Headlight switch trim housing - 945 552 431 00 - excellent condition - $70. Dash (oval) switch steering column surround trim - 945 552 429 00 - excellent condition - $100. Door lock linkage, drop link reverse lever - 944/968 - $10 (944 537 262 02) Door trigger handle Interior trim piece (L or R) - Marine Blue - $30. (94453722900) Door trim speaker tweeter mount (944 645 431 00 left side) - $25 HVAC unit trim/ switch pieces/ face plate/ screw & decal plate etc - 944 653 021 01 - 944 653 203 00 - I am unsure if the unit itself works however all the switch gear (except one missing slider knob) is in excellent condition. Clear plastic screw plate is also excellent. Complete - $200. Face trim plate - $50, individual switches $50, knobs $30 each, inner clear screw plate with decals $60. HVAC aftermarket 3D printed screw plate (new, unused- unfitted) - this was recommended by Buchanan's as a great replacement for the original clear screw plate as the media is much more resilient. Comes from a Canadian company. You will need to remove your current decals & add them to this plate. - $100. Door lock rod clips Genuine Porsche New 99353156300 - $4.00 each. ( I have 10 in total) Retainer spring - Shift lever retainer clip & 2 x circle clips - $10 Interior fixings/ screw (370 piece) set from Classic 9 leather ($92USD to buy new) - plus I have a large number of additional new/ unused interior trim fitment pieces/ door panel clips etc etc - $100. (google "Classic 9 leather" for complete breakdown of kit). Turn signal assembly - Front 944 (86-91) Bosch 0311319002 (left & right) - in excellent/ mint condition - $200 each. Fog light lens trim Right side 1301 0990 48 - $40 Torque Tube/ bell housing Polyurethane Rubber inspection covers (large rectangle -used & small round- new) (477 521 277 C & 931 116 117 00) - $35 for both. Reference Sensor/ Engine crank position sensor bracket x 2 - 1 new/ unused in packaging, 1 used - excellent condition. $100 for new/ $75 for used. (944 101 321 07) Grommet fuel filler drain - $12 (94420146100) Centre Console switch buttons x 2. All working with refreshed decals. 1x central locking, 1 x door mirrors, $30 each Center console & dash decals for refreshing faded switch decals - various $3 each tail light nuts & washers x 4 (free if anyone needs them). Window slot seal (left side) new but slightly damaged - it has a small kink in it - photos would be supplied - it still looks like it would fit & work as normal. - $35. Central locking mechanisms for both doors & hatch $100. Fan & Bosch fan motor, radiator cooling, 87 - 95 928 (92862414500) - no idea of it working status. $25. Seat belts x 4. 2 complete rear seat, 2 with just the shoulder straps & retractors. 944 climate AC heater blower motor assembly. 944 573 015 00. As you can see the outer case is cracked however the inner parts & peripherals seem to be in good order. $50. Headlight pop up complete lift linkage pivot bar assembly -H4 globes, light pods, actuator, motor, brackets. $400. Happy to sell complete or in pieces. Altitude correction sensor 94460615100 - $69. Power steering return line - metal tubing only - $50. Shift Linkage arm (944 424 141 00) , intermediate shift lever (944 424 013 02) - $65. Torque tube Bearings x3, Bearing carriers x4 average condition. $20 each. Drivers window, has tint attached in poor condition, glass is scratched & would need a polish - $60. Sold - Sunroof exterior panel in red with all clips/ fixings. Guards Red $300. sold - Sunroof drive gear 944/968 (85.5 -95) - Genuine from PCB - (944 564 430 01) - $15. Sold - Sunroof Cam (NEW - never fitted) from only 944 - replacement part for 944 564 535 00 - made from metal not plastic - $50. sold - Sunroof seals (inner & outer) - reasonable - $10 each. Sold - '10 speaker' plastic housings ,including main speakers & reconditioned mid speakers . (left 944 555 143 00 L) & (right 944 555 144 00 R) sides, - like new. No cracks in plastic. Excellent condition $580. Sold - Ash tray (85.5-91) this has a chip from one corner -free - you'll just need to pay postage - approx $7. sold - Burco mirror replacement glass (L & R sides) heated - new unopened $25 each. sold - Mirror /door gaskets x 2 (944731 505 01 -left & 945 731 506 01 - right) $15 each sold - Dash (oval) trim piece for clock/ switches etc - 945 552 435 00 - excellent condition - $100 Sold - Door lock operating rod for lock actuator - central locking x 2 Genuine New (944 537 511 00) $10 each sold - Door (left & right side) stop bracket/ arrestor 9924/944/928/968) - part# 92853741703 left // 92853741802 right - genuine new/ unused - $25 each (see next several items to match this) sold - Door check desk pad (gasket/ seal) - new/unused in packaging - 928 537 426 02 - $8 sold - Door stop/ check - new/ unused - 944 537 609 00 - $30. sold - Door (exterior) handle gaskets - 1x genuine Porsche $12. (171 837 211A), 1x Dansk $5 (171837211A-D), Sold - Seat bolts x 12 used / good condition - $10. sold - Shifter vibration dampers 944 (944 424 075 00) - new/ genuine/ unfitted - $20 sold - Arnn Worx RNK1 door strap repair kit (new/ unused) - $20 sold - Hatch lock grommet 944 new unused in packaging $10. sold - Hatch Pin set Stainless Steel RENNBAY - (10-4196-001) - $30 Sold - Hood badge securing grommets x 2 - $5 Sold Hood badge speed nuts x 2 $5 (sold). Interior trim screw covers (clips to the head of screws etc) some new $1 each some used 50c each. I have about 20. Sold - 1x rear wiper switch (rear wiper button comes with a second parts button).. sold - Power Window motor & regulators x 3. $50 each sold - Window slot seals (sometimes referred to as outer door/ window scrapers) (left & right) NEW in packaging/ unfitted. 477 837 469 A (left) // 477 837 470 A (right) - $75 each. Sold - Fuse box lid (85.5.- 91) 944 610 017 01 - excellent condition, decals intact, most fuses. $45 sold - Fuel filler cap 944 (silverblau) & hinge assembly. All decals present & in good order - $35. sold - Hatch/ trunk latch lock motor. (94462402401) $50. Sold - Wiper arms & blades- set of 2 - very good condition/ ready to bolt on. (945 628 028 02) - $50. sold - Rear seats 944, split fold down, cloth script in Marine Blue - very good condition - $200. sold - Valvoline Max Life 20W- 50 semi synthetic oil for engines over 100k. Recommended to me by Buchanan's. I have 3 unopened 5L containers & one container with 4L that was opened 5 days ago. - $35 per bottle unopened. Rob and Port 911 2 Quote Link to comment Share on other sites More sharing options...
Stepo Posted 27July, 2020 Report Share Posted 27July, 2020 Have you thought about using your spare parts to build another car, you have a good start....................sorry mate, just joking micknine01 and Jason E 1 1 Quote Link to comment Share on other sites More sharing options...
Jason E Posted 27July, 2020 Author Report Share Posted 27July, 2020 33 minutes ago, Stepo said: Have you thought about using your spare parts to build another car, you have a good start....................sorry mate, just joking I hear you. I went a bit crazy at times. Every time I saw a really good quality part I couldn't resist. I had a sickness 😀....... Stepo and FAP911 2 Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 27July, 2020 Report Share Posted 27July, 2020 4 minutes ago, Jason E said: I had a sickness 😀....... Had??? ... 🤔 Jason E 1 Quote Link to comment Share on other sites More sharing options...
Jason E Posted 27July, 2020 Author Report Share Posted 27July, 2020 18 minutes ago, Dreamr said: Had??? ... 🤔 touche....... Dreamr 1 Quote Link to comment Share on other sites More sharing options...
Rod C Posted 27July, 2020 Report Share Posted 27July, 2020 PM sent. Quote Link to comment Share on other sites More sharing options...
OzJustin Posted 1August, 2020 Report Share Posted 1August, 2020 Geez mate, you could be the Lart's Parts of Oz! 😄 Quote Link to comment Share on other sites More sharing options...
Jason E Posted 1August, 2020 Author Report Share Posted 1August, 2020 Yes, it's a lot. Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 2August, 2020 Report Share Posted 2August, 2020 Jason What kind of warranty do you have on your parts? Are they in the original, unopened packaging? Thought about opening a museum? Jason E 1 Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 2August, 2020 Report Share Posted 2August, 2020 3 hours ago, brian in buddina said: Jason What kind of warranty do you have on your parts? Are they in the original, unopened packaging? Thought about opening a museum? I reckon you'd get better quality by shopping at Steptoe & Son ... 😎 (love ya Jason!) ... Quote Link to comment Share on other sites More sharing options...
Jason E Posted 2August, 2020 Author Report Share Posted 2August, 2020 8 minutes ago, Dreamr said: I reckon you'd get better quality by shopping at Steptoe & Son ... 😎 (love ya Jason!) ... I'll take that as a compliment..... Dreamr 1 Quote Link to comment Share on other sites More sharing options...
Jason E Posted 21August, 2020 Author Report Share Posted 21August, 2020 Bump Quote Link to comment Share on other sites More sharing options...
Jason E Posted 22August, 2020 Author Report Share Posted 22August, 2020 Updated list with items sold. Quote Link to comment Share on other sites More sharing options...
Jason E Posted 12September, 2020 Author Report Share Posted 12September, 2020 Updated list with items sold. Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 12September, 2020 Report Share Posted 12September, 2020 Might be cheaper for you to buy the few bits your missing and then you could put it on Carsales as complete & in original condition flamingporsche 1 Quote Link to comment Share on other sites More sharing options...
Jason E Posted 12September, 2020 Author Report Share Posted 12September, 2020 11 minutes ago, brian in buddina said: Might be cheaper for you to buy the few bits your missing and then you could put it on Carsales as complete & in original condition You're silly...... Quote Link to comment Share on other sites More sharing options...
