Paul Carrera Posted 31August, 2020 Report Share Posted 31August, 2020 Finally after persevering without a working fuel gauge I decided to pull the sender unit out for a look. The thin wire that sensors the level was broken so I soldered about 20mm of thin copper wire to it and then soldered that to the terminal and now it’s all working as it should. I see this as a temporary repair as I’m sure the joint will fail in time. What I am wanting to know is if I replace the wire completely what can I use in its place as I assume it has to be a certain resistance. Anyone ever done this? Quote Link to comment Share on other sites More sharing options...
