911B Posted 3September, 2020 Report Share Posted 3September, 2020 Hi folks, I need to replace my aircond compressor on my 944S, seems the denso brand is available in us and uk, for similar pricing, just seems so many different companies sell them, does anyone recommend who is most reputable before I send a slab of $ os? cheers George Quote Link to comment Share on other sites More sharing options...
SteveF Posted 3September, 2020 Report Share Posted 3September, 2020 Hi George, When I had mine replaced in my old 944 I was recommended a kit from this company in the US.https://griffiths.com/porsche/air-conditioning/924-944-951-968/porsche-924-944-951-968-ac-compressors-kits/ Cheers Steve Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 4September, 2020 Report Share Posted 4September, 2020 A local mobile air con guy rebuilt mine. Works great. Quote Link to comment Share on other sites More sharing options...
Big Dav Posted 4September, 2020 Report Share Posted 4September, 2020 I got a rebuilt Denso unit about 4 years ago locally for $300 for my '87 911 and it's worked beautifully since then. Quote Link to comment Share on other sites More sharing options...
TINGY Posted 5September, 2020 Report Share Posted 5September, 2020 There is a guy in Melbourne that does them, i can't remember who though sorry, i had one done by him a few years ago for my 944. Unfortunately the 10P15E unit used in the 944's is a use it or lose it type of thing, Every 944 i had ended up in failure. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 5September, 2020 Report Share Posted 5September, 2020 George, Why do you think you need to replace the compressor? Assuming it hasn’t seized due to lack of oil and the only problem is a leaking front seal, they are pretty straight forward to put a new seals kit through. I’ve just done one. About $30 for the seals and $45 for a can ND 8 oil, all readily available off eBay. There are few good DIY videos on YouTube to help too. Port 911 and firstone 2 Quote Link to comment Share on other sites More sharing options...
911B Posted 7September, 2020 Author Report Share Posted 7September, 2020 On 05/09/2020 at 16:10, Peter M said: George, Why do you think you need to replace the compressor? Assuming it hasn’t seized due to lack of oil and the only problem is a leaking front seal, they are pretty straight forward to put a new seals kit through. I’ve just done one. About $30 for the seals and $45 for a can ND 8 oil, all readily available off eBay. There are few good DIY videos on YouTube to help too. Because the support bracket is broken and risks my belts coming off mate, there’s a guy in Sydney that can supply a new denso for about $1100, saves shipping from us for not much less. Cheers guys Quote Link to comment Share on other sites More sharing options...
Peter M Posted 8September, 2020 Report Share Posted 8September, 2020 Jezus! How do you break the mounts on a Denso compressor!!!! I wouldn't have thought that to be impossible. Like to see a photo if you have one handy. If you haven't the time or interest to bugger around I guess $1100 is the cost. However these compressors were used on many cars with often only the front pulley and the manifold specific to the application. These two things can be easily swapped over. Anyway, whatever the solution you choose, good luck! Quote Link to comment Share on other sites More sharing options...
911B Posted 8September, 2020 Author Report Share Posted 8September, 2020 2 hours ago, Peter M said: Jezus! How do you break the mounts on a Denso compressor!!!! I would have thought that to be impossible. Like to see a photo if you have one handy. If you haven't the time or interest to bugger around I guess $1100 is the cost. However these compressors were used on many cars with often only the front pulley and the manifold specific to the application. These two things can be easily swapped over. Anyway, whatever the solution you choose, good luck! I’ll get my mechanic to take a pick when he pulls it out for me. Cheers Peter M 1 Quote Link to comment Share on other sites More sharing options...
944s2cab Posted 26October, 2020 Report Share Posted 26October, 2020 I broke the rear lug on mine, I ally welded it, easily done for someone with the gear and definatly cheaper than a new one Quote Link to comment Share on other sites More sharing options...
Port 911 Posted 27October, 2020 Report Share Posted 27October, 2020 On 05/09/2020 at 16:10, Peter M said: George, Why do you think you need to replace the compressor? Assuming it hasn’t seized due to lack of oil and the only problem is a leaking front seal, they are pretty straight forward to put a new seals kit through. I’ve just done one. About $30 for the seals and $45 for a can ND 8 oil, all readily available off eBay. There are few good DIY videos on YouTube to help too. I have my old one here after replacing mine due to leaks, may have to get a kit to run through it to keep as a spare. Got my new one via Autohaus Quote Link to comment Share on other sites More sharing options...
