Prodigy Posted 23September, 2020 Report Share Posted 23September, 2020 I'm looking to install a Blackvue Dr750s with a Power Magic Pro for parked recording in my 996.2. I'll plug into the fuse box using the 'add a circuit' fuse taps. Those that have done similar what fuse locations have you successfully used for the constant power and Ignition switched power please? Thanks. Quote Link to comment Share on other sites More sharing options...
Prodigy Posted 29September, 2020 Author Report Share Posted 29September, 2020 Anyone able to please assist? Quote Link to comment Share on other sites More sharing options...
firstone Posted 29September, 2020 Report Share Posted 29September, 2020 I have no idea on the 996 sorry. I had one in another car and ran the constant through the firewall to the battery. Inline fuse iirc. Great product btw. Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 29September, 2020 Report Share Posted 29September, 2020 Easy, Using a multimeter or lamp tester (faster) check for any fuse that has power both sides with the ignition off, key removed and use that for the constant power supply, While testing note any fuses that do not have power, with the ignition on recheck the fuses that were off and use any of the fuses that are now alive as your switched supply. Quote Link to comment Share on other sites More sharing options...
jordan Posted 29November, 2020 Report Share Posted 29November, 2020 How much power do you need to run when car is off? If so, might be easier to run it up from cigarette lighter? Quote Link to comment Share on other sites More sharing options...
Prodigy Posted 30November, 2020 Author Report Share Posted 30November, 2020 On 29/11/2020 at 14:37, jordan said: How much power do you need to run when car is off? If so, might be easier to run it up from cigarette lighter? The cigarette lighter doesn't have power once the car is switched off. I ended up using fuses D5 & D10 for the install. firstone and jordan 1 1 Quote Link to comment Share on other sites More sharing options...
jordan Posted 2December, 2020 Report Share Posted 2December, 2020 On 30/11/2020 at 18:53, Prodigy said: The cigarette lighter doesn't have power once the car is switched off. I ended up using fuses D5 & D10 for the install. Ah silly me! Got confused. It does provide low amp though. Quote Link to comment Share on other sites More sharing options...
