911Gbanger Posted 13October, 2020 Report Share Posted 13October, 2020 Hi, I’ve got a stock 3.6l what are your top performance upgrades I could do to squeeze out more power. Eg chip (if so what one) air intake again if so which one ? cheers Quote Link to comment Share on other sites More sharing options...
JV911 Posted 13October, 2020 Report Share Posted 13October, 2020 How deep are your pockets? Without going down the route of an engine rebuild, for the budget-conscious I would do a chip, exhaust and solid engine mounts - it won't make a stack more power but it will at least sound faster. Then some coil-overs and a good suspension set-up so it handles. Airboxes are a waste of time and money. tomo 1 Quote Link to comment Share on other sites More sharing options...
Zelrik911 Posted 14October, 2020 Report Share Posted 14October, 2020 2 hours ago, 911Gbanger said: Hi, I’ve got a stock 3.6l what are your top performance upgrades I could do to squeeze out more power. Eg chip (if so what one) air intake again if so which one ? 993 Varioram and Wong chip. ECU rejig to suit. 993 exhaust with mini muffler. Quote Link to comment Share on other sites More sharing options...
911Gbanger Posted 14October, 2020 Author Report Share Posted 14October, 2020 5 hours ago, JV911 said: How deep are your pockets? Without going down the route of an engine rebuild, for the budget-conscious I would do a chip, exhaust and solid engine mounts - it won't make a stack more power but it will at least sound faster. Then some coil-overs and a good suspension set-up so it handles. Airboxes are a waste of time and money. Ok I should have stipulated just “Bolt ons” - obviously an engine rebuild is the ultimate way but that’s not necessary yet. 4 hours ago, Zelrik911 said: 993 Varioram and Wong chip. ECU rejig to suit. 993 exhaust with mini muffler. Thanks what kind of extra kw can I expect to gain from such a setup over stock? Quote Link to comment Share on other sites More sharing options...
Andy73 Posted 14October, 2020 Report Share Posted 14October, 2020 Of all the changes I've made to my 3.6 964 the MAF has delivered the most in terms of performance benefits. Has made the engine so much more responsive to throttle inputs and, even after a few months I can genuinely feel the difference. Other than that I'd look at engine mounts and coilovers to really enhance the handling. Ultimately the 964 platform is a fantastic momentum car. Dial in the handling and you'll be carrying great speed everywhere. poli84 1 Quote Link to comment Share on other sites More sharing options...
Zelrik911 Posted 15October, 2020 Report Share Posted 15October, 2020 21 hours ago, 911Gbanger said: Ok I should have stipulated just “Bolt ons” - obviously an engine rebuild is the ultimate way but that’s not necessary yet. Thanks what kind of extra kw can I expect to gain from such a setup over stock? The Rennlist 993 forum has lots of relevant information on this subject. Here is an example: "The advantage of the Vram comes from having a variable intake runner system that maintains intake flow velocities, thereby enhancing the momentum effects of the intake charge pulse. The Varioram plenum / intake stacks have three modes, 2 plenums and has a 2 throttle plate progressive throttle body. It works along the same premise as a progressive 2 BBL carburettor back in the "good 'ol days"... To really appreciate the Vram, you have to want better midrange torque. From an overall max. power aspect, there is not much gain. However, the torque increase at 3800 RPM is almost 50 ft. lbs. of torque. If you think about how that effects the torque curve and how that torque would be valuable to the driver at the RPM, then the value of the Vram can be appreciated." Quote Link to comment Share on other sites More sharing options...
911Gbanger Posted 16October, 2020 Author Report Share Posted 16October, 2020 On 14/10/2020 at 16:46, Andy73 said: Of all the changes I've made to my 3.6 964 the MAF has delivered the most in terms of performance benefits. Has made the engine so much more responsive to throttle inputs and, even after a few months I can genuinely feel the difference. Other than that I'd look at engine mounts and coilovers to really enhance the handling. Ultimately the 964 platform is a fantastic momentum car. Dial in the handling and you'll be carrying great speed everywhere. Thanks had a look seems like a nice upgrade. On 15/10/2020 at 12:35, Zelrik911 said: The Rennlist 993 forum has lots of relevant information on this subject. Here is an example: "The advantage of the Vram comes from having a variable intake runner system that maintains intake flow velocities, thereby enhancing the momentum effects of the intake charge pulse. The Varioram plenum / intake stacks have three modes, 2 plenums and has a 2 throttle plate progressive throttle body. It works along the same premise as a progressive 2 BBL carburettor back in the "good 'ol days"... To really appreciate the Vram, you have to want better midrange torque. From an overall max. power aspect, there is not much gain. However, the torque increase at 3800 RPM is almost 50 ft. lbs. of torque. If you think about how that effects the torque curve and how that torque would be valuable to the driver at the RPM, then the value of the Vram can be appreciated." Interact VarioRam upgrade is big bucks Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 7November, 2020 Report Share Posted 7November, 2020 When I had my 964, I ran a cup pipe on the rear and bought a chip from Steve Wong. Yes, it is noticeable.. especially in the mid range. 911Gbanger 1 Quote Link to comment Share on other sites More sharing options...
Spannerhead Posted 18July, 2021 Report Share Posted 18July, 2021 You may have already done something but the Sharkwerks have a kite that is very good. There are a few articles out there that say how much it improves the car. https://www.sharkwerks.com/c_software-tuning There is also the people in the UK who made the ECU and they do a kit thats similar and a little cheaper . https://www.specialist-components.co.uk/index.php/shop/engine-management/posche-engine-management/porsche-911-964-management-kit.html I'm considering one of these or going the hole 3.8 route. Good luck. Quote Link to comment Share on other sites More sharing options...
mark2559 Posted 19August, 2021 Report Share Posted 19August, 2021 Cargraphic have some very high quality exhaust + MAF + Tune upgrades. Slightly pricey, but high quality and deliver on the promises. (Note: NO commercial affiliation by me). Quote Link to comment Share on other sites More sharing options...
