MFX Posted 3March, 2021 Author Report Share Posted 3March, 2021 2 hours ago, OZ930 said: Wouldn’t it “only” be the crown wheel ? I wonder how easy it is, if it could be done. May be a good supply/conversion for early cars if it is. can the gearbox be run upside down? Probably. I have no idea, as the internal workings of gearboxes are still a mystery to me 1 hour ago, Coastr said: People have done this with Subaru trans - flipped it around. At least it’s ‘in the family’, can apparently handle more HP and supply is plentiful. Might even be able to shift down without crunching. Something to ponder for another day. Yes. @MrRPJ had a Subaru trans the was converted to fit in the back of his LS powered 911. He did blow it up, but that was with a lot more torque going through it than your typical aircooled engine. From memory it was cheaper and stronger than buying a 915. Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 3March, 2021 Report Share Posted 3March, 2021 I did a bit of research and yes you can invert the gearbox. Also second gear in the early Boxter is a bit fragile. The 6 speed is stronger than the 5 speed MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 3March, 2021 Author Report Share Posted 3March, 2021 16 minutes ago, OZ930 said: I did a bit of research and yes you can invert the gearbox. Also second gear in the early Boxter is a bit fragile. The 6 speed is stronger than the 5 speed I did know that the 6 speed was better, but that is interesting that it is possible to flip it around. In this episode I weigh both the old Boxster engine and the V8 I am swapping into it, to see just how much extra weight I am adding to the Roxster. tomo and firstone 2 Quote Link to comment Share on other sites More sharing options...
Coastr Posted 3March, 2021 Report Share Posted 3March, 2021 I don’t know much about vag products but in a Bmw you would need the key barrel surround, key, immobiliser, cluster and dme (computer) to get that engine to run. Otherwise if the dme talks to the key barrel and the immobiliaer then the cluster and they don’t agree they all belong to the same car no start. Maybe all this stuff has been worked out with engine swaps and coding but I would be hanging onto that body until you have the engine running in the new car. Otherwise you have to junk the factory computer amd run an aftermarket one. Quote Link to comment Share on other sites More sharing options...
MFX Posted 4March, 2021 Author Report Share Posted 4March, 2021 10 hours ago, Coastr said: I don’t know much about vag products but in a Bmw you would need the key barrel surround, key, immobiliser, cluster and dme (computer) to get that engine to run. Otherwise if the dme talks to the key barrel and the immobiliaer then the cluster and they don’t agree they all belong to the same car no start. Maybe all this stuff has been worked out with engine swaps and coding but I would be hanging onto that body until you have the engine running in the new car. Otherwise you have to junk the factory computer amd run an aftermarket one. I will be hanging on to the car until it is running, but guys have got it running with both Porsche and Audi ecu's running together and they dont need the key. So hopefully it whould not be too crazy. Coastr and firstone 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 17March, 2021 Author Report Share Posted 17March, 2021 This week I quickly recap the damage to Harry 911 and then I get stuck into fitting the engine into the Roxster. firstone, tomo and Scott930 3 Quote Link to comment Share on other sites More sharing options...
michel Posted 18March, 2021 Report Share Posted 18March, 2021 22 hours ago, MFX said: This week I quickly recap the damage to Harry 911 and then I get stuck into fitting the engine into the Roxster. https://youtu.be/WqPyF_BtV64 progress is progress jeff any thought to cutting away unnecessary rear inner sheet metal -ala 560 e.g rear luggage area and putting back a frame /extra tubing to reinforce if required Quote Link to comment Share on other sites More sharing options...
MFX Posted 24March, 2021 Author Report Share Posted 24March, 2021 This week I get stuck into fabricating a subframe to mount the Audi V8 into the Roxster. Cheshire Cat and tomo 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 31March, 2021 Author Report Share Posted 31March, 2021 This week I finish off the subframe to mount the Audi V8 into the Roxster. This includes the engine mounts, gussets and crush tubes. 3legs, firstone and tomo 3 Quote Link to comment Share on other sites More sharing options...
3legs Posted 1April, 2021 Report Share Posted 1April, 2021 Hey Jeff, that subframe would look great Cad Plated. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 13April, 2021 Author Report Share Posted 13April, 2021 This week I work on plumbing in the radiator and power steering pumps from the Audi engine to the Roxster. P-Kay, firstone, Scott930 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
MFX Posted 5May, 2021 Author Report Share Posted 5May, 2021 This week I get the gear linkages connected and do my favourite thing. Pull the engine out again, so I can trial fit the V8 conversion clutch and flywheel. Scott930 and tomo 2 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 6May, 2021 Report Share Posted 6May, 2021 If it’s just a track hack, couldn’t you just cut a hole into the rear boot for the intake ? Quote Link to comment Share on other sites More sharing options...
MFX Posted 6May, 2021 Author Report Share Posted 6May, 2021 12 hours ago, OZ930 said: If it’s just a track hack, couldn’t you just cut a hole into the rear boot for the intake ? I definitely looked at that, but there is a big structural beam right in the way. If I can use the factory side scoop for the air feed is also a plus. OZ930 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 19May, 2021 Author Report Share Posted 19May, 2021 This week I continue to make space to fit the intake plumbing on the Roxster and I have another look at the sub frame I made previously. tomo and Scott930 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 2June, 2021 Author Report Share Posted 2June, 2021 This week I am back on the Roxster and I start delving into the Audi wiring harness and finalise the engine sub frame. tomo and Scott930 1 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 24June, 2021 Author Report Share Posted 24June, 2021 The last couple of weeks I have been playing around with the factory Audi ECU to get it running on the Roxster. This involves removing the immobiliser and lets just say it didn't go as planned. 3legs, Fishcop, tomo and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
Coastr Posted 24June, 2021 Report Share Posted 24June, 2021 Was watching saying ‘in-line fuse!!!’ That power pack can deliver some serious amps. bummer! I think next time try and crack itv while it was still in the Audi. Quote Link to comment Share on other sites More sharing options...
Jaffar Posted 28June, 2021 Report Share Posted 28June, 2021 Jeff, Just had a look at your YouTube video. You may have been given a few bum steers. In order to set up a working can bus and make make the ecu talk with the OBDi port you need a gateway. That part is Audi 8T0 907 468R. The A6 you got the motor from should have one somewhere behind the dash. Many manufacturers use a gateway of some description to tie up all the data processing. I have one you can have if you still want to have a go at flashing the ecu. When I had plans of putting a Audi 3.2ltr V6 in my 944, as it was direct injection, the only cost effective solution was the Audi ecu and I found that hooking the bastard up was not that easy and hence the discovered the above gateway. Thankfully in the end the motor was toast and I went down a different track. Also 12v anywhere near a USB port is death to the USB board which in turn will cause the laptop to not power up. Try opening it up and disconnecting that USB port and you may find the lappy will play again. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 29June, 2021 Author Report Share Posted 29June, 2021 12 hours ago, Jaffar said: Jeff, Just had a look at your YouTube video. You may have been given a few bum steers. In order to set up a working can bus and make make the ecu talk with the OBDi port you need a gateway. That part is Audi 8T0 907 468R. The A6 you got the motor from should have one somewhere behind the dash. Many manufacturers use a gateway of some description to tie up all the data processing. I have one you can have if you still want to have a go at flashing the ecu. When I had plans of putting a Audi 3.2ltr V6 in my 944, as it was direct injection, the only cost effective solution was the Audi ecu and I found that hooking the bastard up was not that easy and hence the discovered the above gateway. Thankfully in the end the motor was toast and I went down a different track. Also 12v anywhere near a USB port is death to the USB board which in turn will cause the laptop to not power up. Try opening it up and disconnecting that USB port and you may find the lappy will play again. There are plenty who have done it the way I did, but the cable I bought had a chip that wasn't compatible to their software. Either way, I am going to go for a full stand alone as it will be better for future growth. Fishcop and P-Kay 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 29July, 2021 Author Report Share Posted 29July, 2021 This week I finally start mounting the engine for the final time. Fitting in the new air filter and cobbling together an exhaust. Scott930 and tomo 2 Quote Link to comment Share on other sites More sharing options...
Sov Posted 29July, 2021 Report Share Posted 29July, 2021 On 22/10/2020 at 18:34, MFX said: This is definitely the ugliest Porsche in Australia (and possibly the world). I would like to introduce the new Home Built project car, the '98 Porsche Boxster with a host of very questionable modifications. I'd like to own up to one of those questionable modifications. I had that exact eagle sticker on the sunroof of my Mark IV Cortina as a teen. The car in question was cream with a vinyl roof, louvres on the back window, and air horns that played La Cucaracha. The engine was so knackered it wouldn't do a skid so we'd roll it backwards down a hill near my friends house in the rain and then slam it into drive. Ahhh, good times. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 29July, 2021 Author Report Share Posted 29July, 2021 47 minutes ago, the_sovereign_man said: I'd like to own up to one of those questionable modifications. I had that exact eagle sticker on the sunroof of my Mark IV Cortina as a teen. The car in question was cream with a vinyl roof, louvres on the back window, and air horns that played La Cucaracha. The engine was so knackered it wouldn't do a skid so we'd roll it backwards down a hill near my friends house in the rain and then slam it into drive. Ahhh, good times. I may have done the same in my car as a teenager which was a Datsun 200B wagon named 'the sponge', which accurately described it's handling Sov 1 Quote Link to comment Share on other sites More sharing options...
Uncle Posted 2August, 2021 Report Share Posted 2August, 2021 I have never done anything like* that. *I have done exactly that many many times. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12August, 2021 Author Report Share Posted 12August, 2021 This week I go through the process of installing the Link ECU in the Roxster and hopefully to to explain that it is not as difficult that it would first seem. Scott930, Fishcop and tomo 3 Quote Link to comment Share on other sites More sharing options...
