Mike D'Silva Posted 30November, 2020 Report Share Posted 30November, 2020 I recently had to replace just the pressure line in an aircooled 911 - the line that runs down through the centre tunnel, and Len Cummings in the USA makes a great product, which I ordered. However, due to shipping delays, I ended up having to make do with a Genuine Porsche product, that was a massive pain in the arse to fit. The beauty of the line from Len Cummins, is that he makes it so the front part of the line, that connects to the pump itself, is made detachable. For some reason, the gen Porsche item is a 1 piece affair, and you have to get it to run through the car and manouvre it above the steering rack etc.. or if you like, you can lower the steering rack!! The 2 piece line from Len means you can fit it much more easily. I've attached some photos.. Len supplied the line with new copper crush washers, new rubber grommets for where the line passes through the chassis, and also a nice little female coupler that allows you to attach the new line to the rear of the old line, then draw the old line through the front of the car and at the same time, draw the new line through the tunnel perfectly. Also, the line from Len utilises the same fitting at the rear to connect to your stock hard lines that feed into the engine bay. The Gen Porsche line, has a totally different fitting, that requires adapters be made to your hard lines.. ask me how I know.. Anyhow, these lines owe me $280 USD which is approx 380 AUD but I am obviously open to offers. Mike Quote Link to comment Share on other sites More sharing options...
DoMiester Posted 25March, 2021 Report Share Posted 25March, 2021 Hi Mike, I was googling Len and came across your post. If still available I might be interested for a Targa 1982 sc Your photos are not loading, can you reply or PM me with photos etc, i'll give you my location and we can talk $$$ Cheers Dom Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 25March, 2021 Author Report Share Posted 25March, 2021 5 hours ago, DoMiester said: Hi Mike, I was googling Len and came across your post. If still available I might be interested for a Targa 1982 sc Your photos are not loading, can you reply or PM me with photos etc, i'll give you my location and we can talk $$$ Cheers Dom hi Dom I reposted the photos... Quote Link to comment Share on other sites More sharing options...
DoMiester Posted 26March, 2021 Report Share Posted 26March, 2021 Hi Mike, Its fuel pressure line pump to filter. Return line to tank not included? is that correct? Thanks Dom Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 26March, 2021 Author Report Share Posted 26March, 2021 yes sort of. It doesn't go all the way to the filter.. it goes to the hard line, that connects to the filter. But yes, it is the pressure line only. No return line. Quote Link to comment Share on other sites More sharing options...
DoMiester Posted 26March, 2021 Report Share Posted 26March, 2021 Sorry you are right! Sent you a PM Thanks Dom Quote Link to comment Share on other sites More sharing options...
