Jason E
Parts - 944/924/968 - Brisbane (will post)
predominantly from a 944S2.
Some are new genuine parts, unopened & still in original packaging from either Porsche Centre Brisbane, Pelican Parts, Paragon or similar OEM resellers etc.  Many of the used parts are in excellent condition & some are "normal" condition used parts I have acquired over the last 4 years.
 Happy to provide further info or photos by PM, email or text to interested inquirers.  Can definitely post parts to you for better than standard Auspost rates.
I will supply photos of parts & part numbers so you can see what you are getting on request.
Located Brisbane, Northside.
0410439764
 Sunroof interior sacrificial plastic trim clips (required to secure interior trim panel to the exterior panel) - these are new from PCB - $2.00 each - I have 15.
Wheel nuts x 24 - reasonable - $15.
Door lock linkage, drop link reverse lever - 944/968 -   $10   (944 537 262 02)
Door trigger handle Interior trim piece (L or R) - Marine Blue - $30.  (94453722900)
Door trim speaker tweeter mount (944 645 431 00 left side) - $25
Fog light lens trim Right side 1301 0990 48 - $40
Torque Tube/ bell housing Polyurethane Rubber inspection covers (large rectangle -used & small round- new) (477 521 277 C & 931 116 117 00) - $35 for both.
Reference Sensor/ Engine crank position sensor  bracket x 2 - 1 new/ unused in packaging, 1 used - excellent condition.  $100 for new/ $75 for used.  (944 101 321 07)
tail light nuts & washers x 4 (free if anyone needs them).
Window slot seal (left side) new but slightly damaged - it has a small kink in it - photos would be supplied - it still looks like it would fit & work as normal. - $35.
944 climate AC heater blower motor assembly.  944 573 015 00.  As you can see the outer case is cracked however the inner parts & peripherals seem to be in good order.  $30.
Headlight pop up complete lift linkage pivot bar assembly -H4 globes, light pods, actuator, motor, brackets.  $299.   Happy to sell complete or in pieces.
Altitude correction sensor 94460615100 - $69.
Power steering return line - metal tubing only - $50.
Shift Linkage arm (944 424 141 00) , intermediate shift lever (944 424 013 02) - $65.
Torque tube Bearings x3, Bearing carriers x4 average condition.  $20 each.
Share this post
Link to post
Hi, have you got a radiator? Cheers, Sohan
Share this post
Link to post
Bump - buy my stuff please you stingy 944 owners.  I'm doing discounts for bulk orders plus you get a signed photo of myself - bargain.
Share this post
Link to post
Do you still have the seat belts. The driver's side belt on my 944 is very reluctant to retract. If so what are the prices?
Share this post
Link to post
Hi Wardy, this is what I have left in the seatbelts.  I can send you more detailed photos when I get home.
Share this post
Link to post
OK thanks I suppose my only question would be would any of these suit drivers side. Would also probably look at renewing the passenger side if they didn't match.
PS What area of Brisbane are you in.
Share this post
Link to post
seatbelts sold now.
Share this post
Link to post
Thanks, sorry for the belated reply. On another matter you wouldn't know of a source for a Denso Nippon A/C compressor for a 1986  944 Turbo. The one in the car is leaking from the seal and I have been told that that compressor would have to be rebuilt as you can't get new compressor to fit this car. This is from a Porsche independent specialist.
Share this post
Link to post
Sorry, no knowledge on source.  I had Buchanan's in Sydney refurbish my AC system.  They replaced the old Serpentine system with a parallel flow system.  AC was perfect after that.  Worth the money I think.  You could ring Buchanan's- they are generous with their knowledge and time.
Share this post
Link to post
So you would advise having the compressor refurbished AND to replace the serpentine condenser with a parallel condenser. Was this an expensive job?
Share this post
Link to post
I had this done as a much larger body of work by Buchanan's.  I live in Brisbane so AC was important to me.  I think the AC was more than 1k but less than 2k.
Share this post
Link to post
Thanks for this I'm only glad we are going in to Winter as I'm in Brisbane as well. Do you know of any good A/C people in Brisbane or surrounds?
Share this post
Link to post
To be honest I don't.   I had real trouble trying to find decent service from the Indy's here in Brisbane for my 944.  If I still owned it I'd take it back to Buchanan's for any major work.
Share this post
Link to post
PFA [Porsche Forum Australia]
This is an online platform for like-minded Porsche fans/fanatics/tragics to come together to read, chat and share.
It is also a platform to arrange and participate in off-line social meet-ups, events and drives.
