Merv Posted 9January, 2021 Report Share Posted 9January, 2021 My '88 Carrera 911 has its original DME relay. I suspect it is playing up randomly. I see that there are now solid state versions available. Are they available in Australia? Quote Link to comment Share on other sites More sharing options...
OzJustin Posted 9January, 2021 Report Share Posted 9January, 2021 4 hours ago, Merv said: My '88 Carrera 911 has its original DME relay. I suspect it is playing up randomly. I see that there are now solid state versions available. Are they available in Australia? I haven't heard of any Australian distributors but you can order directly from Focus 9. I ordered one for my old 944 S2 a while back and it arrived quickly and performed well (the pump prime feature helped too). https://www.ftech9.com/new-products?category=SSR+(Solid-State+Relays) Quote Link to comment Share on other sites More sharing options...
Merv Posted 9January, 2021 Author Report Share Posted 9January, 2021 Thanks I saw those. I am these days most reluctant to buy anything from the US but our exchange rate has improved and it is a small item. I will drop them a line and confirm which model I need. Is the pump prime function needed on the 911 3.2 87-88? Quote Link to comment Share on other sites More sharing options...
FAP911 Posted 9January, 2021 Report Share Posted 9January, 2021 1 hour ago, Merv said: Thanks I saw those. I am these days most reluctant to buy anything from the US but our exchange rate has improved and it is a small item. I will drop them a line and confirm which model I need. Is the pump prime function needed on the 911 3.2 87-88? They have the flat pins - My 84 has round pins and Focus 9 have no listing for our G series cars Quote Link to comment Share on other sites More sharing options...
Nicko82 Posted 9January, 2021 Report Share Posted 9January, 2021 I had a relay go on my BMW (was intermittently working). I opened it up and saw that a crack had developed in the solder right around a pin that went through the circuit board so as it moved around, sometimes the circuit would work and sometimes it wouldn't. It was an easy fix just to apply a soldering iron to the cracked solder and repair the crack. Worth having a look inside before you buy another one. Quote Link to comment Share on other sites More sharing options...
Merv Posted 10January, 2021 Author Report Share Posted 10January, 2021 1 hour ago, FAP911 said: They have the flat pins - My 84 has round pins and Focus 9 have no listing for our G series cars Interesting. I have written to them to check that very point. Let's see what they say. The cracking solder joints could be a heat related problem as I have noticed that the original DME's get rather hot at times. A friend has drilled small holes in his DME case to provide some venting and found that useful. How much are new DME's from Porsche? It is useful to have a spare in the trunk I figure. Quote Link to comment Share on other sites More sharing options...
Merv Posted 7February, 2021 Author Report Share Posted 7February, 2021 These solid state DMEs seem very good and at $65 for the pump prime model, good value. Fitted one just now. Does not get hot like the heat producing originals. firstone 1 Quote Link to comment Share on other sites More sharing options...
