iffarrukh Posted 29April, 2021 Report Posted 29April, 2021 Hi Folks Just a friendly post, I have full working PIWIS II in Melbourne now and have made some good changes with it. If anyone is looking to enable some features which require PIWIS, I am more than happy to assist. The PIWIS II can work on all cars up to 2016 (not sure about 2017 but will depend if it still have the earlier model hardware) Some of the things I have done using PIWIS II on my Cayenne GTS 2016 - Install and enable ACC (Calibration done at a proper shop) - Install and enable HomeLink - Install and enable factory tow hitch - Some other minor tweaks (disable start/stop, able to turn off DRL(I go to drive in cinema so needed that ), FYI, Anything you want to do would be at your own risk. slknv 1 Quote
slknv Posted 23May, 2021 Report Posted 23May, 2021 Would it work for general diagnostics on an early 996.1? My car has been resting for a few months while I've been trying to diagnose some weird eletrical glitches, and my basic OBD reader doesn't interpret all the porsche reading Quote
iffarrukh Posted 15June, 2021 Author Report Posted 15June, 2021 Yes, it does cover Porsche 911 (996/997) Quote
James P Posted 16June, 2021 Report Posted 16June, 2021 @iffarrukh Are you selling the PIWIS? I would be interested Quote
iffarrukh Posted 16June, 2021 Author Report Posted 16June, 2021 @James P Sorry, I use it often so not selling. But you can buy one from following website(I bought from here as well) . https://www.obd2tool.com/ And if you are in Mel, Happy to let you have a look and test/use it before you buy. James P 1 Quote
Merv Posted 19June, 2021 Report Posted 19June, 2021 Looks useful. For general diagnostics I have found the iCarSoft valuable. Not costly and doesn't need a computer interface. Most of the PIWIS only work on PCs, not Macs - leaving out a significant market sector. Fishcop 1 Quote
Gerk Posted 9December, 2022 Report Posted 9December, 2022 On 29/04/2021 at 10:18, iffarrukh said: Hi Folks Just a friendly post, I have full working PIWIS II in Melbourne now and have made some good changes with it. If anyone is looking to enable some features which require PIWIS, I am more than happy to assist. The PIWIS II can work on all cars up to 2016 (not sure about 2017 but will depend if it still have the earlier model hardware) Some of the things I have done using PIWIS II on my Cayenne GTS 2016 - Install and enable ACC (Calibration done at a proper shop) - Install and enable HomeLink - Install and enable factory tow hitch - Some other minor tweaks (disable start/stop, able to turn off DRL(I go to drive in cinema so needed that ), FYI, Anything you want to do would be at your own risk. Hi Iffarrukh, I have read that PIWIS can be used to program a Macan I (MY15) for white instrument dials. This would have the effect of having backlighting on the speedo and tacho when driving in daylight on DRLs. Are you able to do this with your PIWIS equipment? I can supply the necessary coding. Thank you. Quote
mausling Posted 17November, 2023 Report Posted 17November, 2023 Hi Iffarrukh, Reaching out to you as I've just replaced my 957 instrument cluster with that from a turbo model. Working perfectly except I'd like to change the odo to be correct and also another couple of settings to correct errors due to vin mismatch etc. I'm more than happy to pay you for the use of the PIWIS 2. Please let me know if this is something you'd be willing to help me with. Cheers Quote
SlowCarPls Posted 30September, 2024 Report Posted 30September, 2024 On 29/04/2021 at 10:18, iffarrukh said: Hi Folks Just a friendly post, I have full working PIWIS II in Melbourne now and have made some good changes with it. If anyone is looking to enable some features which require PIWIS, I am more than happy to assist. The PIWIS II can work on all cars up to 2016 (not sure about 2017 but will depend if it still have the earlier model hardware) Some of the things I have done using PIWIS II on my Cayenne GTS 2016 - Install and enable ACC (Calibration done at a proper shop) - Install and enable HomeLink - Install and enable factory tow hitch - Some other minor tweaks (disable start/stop, able to turn off DRL(I go to drive in cinema so needed that ), FYI, Anything you want to do would be at your own risk. What a legend. PM sent. Quote
Miffy Posted 30September, 2024 Report Posted 30September, 2024 I also have one. SW of WA. Been quite interesting investigating… PM me if needed. Quote
t888 Posted 13November, 2024 Report Posted 13November, 2024 Anyone in Canberra got one? \ @michel maybe? Need to do some coding, happy to pay for an hour or two of usage. Quote
michel Posted 16November, 2024 Report Posted 16November, 2024 On 14/11/2024 at 10:29, t888 said: Anyone in Canberra got one? \ @michel maybe? Need to do some coding, happy to pay for an hour or two of usage. I do Its down the sth coast at the moment Quote
phelips Posted Sunday at 00:11 Report Posted Sunday at 00:11 Hey mate, Nice work with the PIWIS II! Good to know there’s someone local who can help with coding. Might hit you up for a few tweaks on my Cayenne. Cheers. Quote
