Hello,
I am in the process of restoring my dashboard on a 1974 911. There is a crack in the middle of the dash top. I am looking to either replace with new, or recover. I would like to know what method will be most authentic to the original design.
Option 1 - remove and send to dash doctor
Option 2 - remove and have vinyl wrapped(need to source correct vinyl for a 74)
Option 3 - replace with this item (speaker grill is incorrect) https://www.ebay.com.au/itm/223662348372?hash=item3413509854:g:iZcAAOSwWm9c8Fw1
I have attached photos of the dash below.
I am also looking at restoring/ replacing the glove box lid and front fascia panels.
Any suggestions would be most welcome.
Thank You.
3 minutes ago, generalsmirnov said:
incorrect about it
Speaker holes are not square as your original one
It still is a LHD dashpad right? Or are my eyes broken?
I think the dash doctor was my original preference - but I am unsure how they would go about rectifying the foam material underneath - from what I understand vacuum formed is the way to go.
I couldn’t find the correct dashboard from dash original and the fibreglass isn't ideal.
The eBay listing has RHD versions but I will most likely need to source the speaker grille part from stoddards. Just unsure about quality.
Has anyone used the dash doctor - I’d like to have the dashboard in steel and as close to factory as possible.
Interestingly Porsche sell the dashboard new albeit with the later Center vents for quite a reasonable amount of anyone is looking.
