TheBaywatchKid Posted 23July, 2021 Report Share Posted 23July, 2021 I was checking my rear right wheel well, and saw this loose ground wire. Anyone know where it's from? Assume it should be connected to that loose pin on the top right of the pic. TIA! Quote Link to comment Share on other sites More sharing options...
Aus911 Posted 23July, 2021 Report Share Posted 23July, 2021 Hi, My rear right wheel well has the oil tank so you cant really get access to view this, however I looked in my left wheel well and that wire is mounted to upper bolt of the bumper bar mounting bracket. Your wire is almost over the bolt where mine is mounted. I tried getting a pic, see attached, if you need another let me know! I hope this makes sense and helps! And yes, I now realize it needs cleaning!!! Cheers Ray TheBaywatchKid 1 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 24July, 2021 Author Report Share Posted 24July, 2021 Ah awesome thank you! Quote Link to comment Share on other sites More sharing options...
