philipk Posted 19September, 2021 Report Share Posted 19September, 2021 On 16/09/2021 at 19:20, wangan said: It's more for the damage that's done when the air con isn't on though really. Cold nights, humid days etc. Thanks @tomo can you use plaster, ply and cement sheeting with this? Thanks @philipk is there any issue with just installing the insulation from underneath instead of taking the sheets off? Or is it better to remove sheets? I might get a few quotes. You are better off removing the sheets and putting on insulation paper over the roofing frame then put the roof back on. This will create a vapour barrier and stop the condensation coming inside the garage. rminc and WB997.2GTS 2 Quote Link to comment Share on other sites More sharing options...
rminc Posted 19September, 2021 Report Share Posted 19September, 2021 14 hours ago, philipk said: You are better off removing the sheets and putting on insulation paper over the roofing frame then put the roof back on. This will create a vapour barrier and stop the condensation coming inside the garage. I think that's the best way. Should not be too expensive either. I don't know if you'll even need it to be honest. The walls look insulated already. A quick YouTube search even states that you don't really need it, but I'm no expert. Videos only a minute and a half long. Should give you some piece of mind. Quote Link to comment Share on other sites More sharing options...
sus911 Posted 19September, 2021 Report Share Posted 19September, 2021 On 18/09/2021 at 10:00, rminc said: The pitch of his garage looks to be around 45 degrees. Wouldn't that be sufficient to channel condensation out? Others have said above that you could do it without removing the sheets, but as sus911 has said, the whole point is to create a barrier, you won't have a sealed barrier doing it from underneath I would think. Only was is for the sheets to come off. This thread has made me a bit paranoid about my colourbond garage now 🤔 45° is helpful but as you acknowledge is not a physical barrier. Another point to note is that formation of condensation could indicate a lack of ventilation. Quote Link to comment Share on other sites More sharing options...
rminc Posted 20September, 2021 Report Share Posted 20September, 2021 20 hours ago, sus911 said: 45° is helpful but as you acknowledge is not a physical barrier. Another point to note is that formation of condensation could indicate a lack of ventilation. Hypothetically if there was ventilation, say a whirly bird. I don't think that has much to do with the condensation. You'll still condensation under a colour bond pergola and that has plenty of ventilation. Quote Link to comment Share on other sites More sharing options...
911 Posted 23September, 2021 Author Report Share Posted 23September, 2021 On 20/09/2021 at 21:54, rminc said: Hypothetically if there was ventilation, say a whirly bird. I don't think that has much to do with the condensation. You'll still condensation under a colour bond pergola and that has plenty of ventilation. Thanks everyone. I guess we will see how we go over winter with the condensation. I don't think there will be any damage during the summer being uninsulated right? The garage gets hot, but it's not in direct sunlight. Quote Link to comment Share on other sites More sharing options...
