Fishcop Posted 19September, 2021 Report Share Posted 19September, 2021 My car has a fabulous and fully documented history, so I know at 18 years and 60,000kms it hasn't had its water pump changed. I'm told the water pump will fail at some time... So I've ordered in a new pump, cooler (78ºC) thermostat, drive belt and 25 litres of coolant! I'm told there is an upgraded coolant cap available, but haven't been able to confirm - anyone aware of this? Weather has been great for driving - so waiting for a run of crap weather to enjoy the garage 911CSR and Rod C 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 19September, 2021 Report Share Posted 19September, 2021 Following the bleeding technique was a real pain. I have since bought a vacuum bleeder kit which is the preferred way and I think it will save a heap of headaches next time. I think it is worth looking into Fishcop 1 Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 19September, 2021 Author Report Share Posted 19September, 2021 5 minutes ago, MFX said: Following the bleeding technique was a real pain. I have since bought a vacuum bleeder kit which is the preferred way and I think it will save a heap of headaches next time. I think it is worth looking into Thanks for the advice Jeff. I watched your video and recall you mentioning it was tedious I think I can borrow a vacuum bleeder from a friend of a friend if I ask very nicely. And provide beer. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 19September, 2021 Report Share Posted 19September, 2021 33 minutes ago, Fishcop said: Thanks for the advice Jeff. I watched your video and recall you mentioning it was tedious I think I can borrow a vacuum bleeder from a friend of a friend if I ask very nicely. And provide beer. Worth the beers. It took around 5 or 6 goes getting it hot and keep topping it up. It was pretty stressful as I didn't want to over heat it. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 19September, 2021 Report Share Posted 19September, 2021 Air cooled 👍😅😉 I'll leave now 👋👋👋 micknine01, michel, Fishcop and 1 other 4 Quote Link to comment Share on other sites More sharing options...
sjm Posted 19September, 2021 Report Share Posted 19September, 2021 10 hours ago, Fishcop said: My car has a fabulous and fully documented history, so I know at 18 years and 60,000kms it hasn't had its water pump changed. I'm told the water pump will fail at some time... So I've ordered in a new pump, cooler (78ºC) thermostat, drive belt and 25 litres of coolant! I'm told there is an upgraded coolant cap available, but haven't been able to confirm - anyone aware of this? Weather has been great for driving - so waiting for a run of crap weather to enjoy the garage Did the same as you on my 997.1 at 60k’s. Water pump was fine but at 15 years old and quite a few redlines, probably not bad peace of mind. Didn’t do the coolant flush, thought I’d leave that to Buiks when in for annual service. What is the consensus on replacing coolant? Quote Link to comment Share on other sites More sharing options...
Jimmy Posted 19September, 2021 Report Share Posted 19September, 2021 11 hours ago, Fishcop said: My car has a fabulous and fully documented history, so I know at 18 years and 60,000kms it hasn't had its water pump changed. I'm told the water pump will fail at some time... So I've ordered in a new pump, cooler (78ºC) thermostat, drive belt and 25 litres of coolant! I'm told there is an upgraded coolant cap available, but haven't been able to confirm - anyone aware of this? Weather has been great for driving - so waiting for a run of crap weather to enjoy the garage I had this exact coolant in my 996 and after about 6 to 12 months l started seeing sludge residue around expansion tank neck. I took it to Nick Cascone and he said wrong coolant and he's sees problems with seals deteriorating. I had him flush it out and put in the proper OEM Porsche coolant, it's been about 3 months now and the sludge has hugely reduced and starting to disappear. If it was me l'd take it back for a refund. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 20September, 2021 Report Share Posted 20September, 2021 My independent Porsche trained mechanic suggested that the same would happen when I said I was changing the coolant, he recommended Ravenol (Porsche Spec), i went with the recommendation and have not had a problem. Its not cheap Fishcop 1 Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 20September, 2021 Report Share Posted 20September, 2021 1 hour ago, WB997.2GTS said: My independent Porsche trained mechanic suggested that the same would happen when I said I was changing the coolant, he recommended Ravenol (Porsche Spec), i went with the recommendation and have not had a problem. Its not cheap Is that the blue one? That's what my mechanic changed mine to. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
911CSR Posted 20September, 2021 Report Share Posted 20September, 2021 14 hours ago, Fishcop said: I'm told there is an upgraded coolant cap available, but haven't been able to confirm - anyone aware of this? This is the only "upgraded" coolant cap I have found in my many hours of searchign around: https://lnengineering.com/products/brs-parts-and-upgrades/cooling/billet-aluminum-boxster-cayman-911-coolant-expansion-tank-cap.html Fishcop 1 Quote Link to comment Share on other sites More sharing options...
st3ve Posted 20September, 2021 Report Share Posted 20September, 2021 (edited) There's been a few revisions of the cap over the years, latest is -04. So 996 106 447 04. That might be what you mean re upgraded cap? I have one here waiting for me to get a few other projects off my list before doing clutch, expansion tank and various other "while you're at its" like the water pump and full flush. Interested to read about coolant type, I was wondering about that. With my Beemers I'm only using genuine coolant which is cheap and easy to get from clickable auto. For the Porker I presumed that would be the best way to go as well, though I'd rather buy it elsewhere than a dealership. The 996 requires a roughly a swimming pool of it, 24lt or something! <EDIT: By "that would be the best way to go" I meant using genuine coolant ie Porsche, not BMW in case it was unclear. Everyone who's been to Germany knows that Bavaria and Baden-Wurtenburg mix like oil and water! :D> Edited 20September, 2021 by st3ve Fishcop 1 Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 20September, 2021 Report Share Posted 20September, 2021 6 hours ago, TwoHeadsTas said: Is that the blue one? That's what my mechanic changed mine to. This, I hope it was the correct product, no sludge issues Fishcop 1 Quote Link to comment Share on other sites More sharing options...
Jimmy Posted 20September, 2021 Report Share Posted 20September, 2021 4 hours ago, st3ve said: There's been a few revisions of the cap over the years, latest is -04. So 996 106 447 04. That might be what you mean re upgraded cap? I have one here waiting for me to get a few other projects off my list before doing clutch, expansion tank and various other "while you're at its" like the water pump and full flush. Interested to read about coolant type, I was wondering about that. With my Beemers I'm only using genuine coolant which is cheap and easy to get from clickable auto. For the Porker I presumed that would be the best way to go as well, though I'd rather buy it elsewhere than a dealership. The 996 requires a roughly a swimming pool of it, 24lt or something! I believe VW use the exact same coolant as Porsche but at significant lower price. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 20September, 2021 Author Report Share Posted 20September, 2021 Thanks heaps for the heads up regarding the coolant - I did a bit of searching and noted the Penrite red had been used by a few people (with a clear declaration that the green colour is wrong). @MFX was it Penrite you used? Pretty sure I can take back the Penrite - even if it's just for a shop credit. I presume it's the original 18 year old coolant in the system at the moment... It's a urine yellow colour. Funny enough my independent VW tech (Amarok) uses Ravenol exclusively, so I know I can get my hands on it... Looks like more homework is needed 😕 Quote Link to comment Share on other sites More sharing options...
MFX Posted 20September, 2021 Report Share Posted 20September, 2021 7 minutes ago, Fishcop said: Thanks heaps for the heads up regarding the coolant - I did a bit of searching and noted the Penrite red had been used by a few people (with a clear declaration that the green colour is wrong). @MFX was it Penrite you used? Pretty sure I can take back the Penrite - even if it's just for a shop credit. I presume it's the original 18 year old coolant in the system at the moment... It's a urine yellow colour. Funny enough my independent VW tech (Amarok) uses Ravenol exclusively, so I know I can get my hands on it... Looks like more homework is needed 😕 Yep, I used the Penrite Red stuff. From what I can gather it is correct for the car. Merv and Fishcop 2 Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 20September, 2021 Author Report Share Posted 20September, 2021 Update - My VAG Tech confirms Ravenol LTC or LGC for the VWs and Audis he services - he has a 10 litre jug for me... Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 20September, 2021 Report Share Posted 20September, 2021 2 hours ago, Fishcop said: Thanks heaps for the heads up regarding the coolant - I did a bit of searching and noted the Penrite red had been used by a few people (with a clear declaration that the green colour is wrong). @MFX was it Penrite you used? Pretty sure I can take back the Penrite - even if it's just for a shop credit. I presume it's the original 18 year old coolant in the system at the moment... It's a urine yellow colour. Funny enough my independent VW tech (Amarok) uses Ravenol exclusively, so I know I can get my hands on it... Looks like more homework is needed 😕 From the reading I have done, it definitely shouldn't be yellow (or any shade thereof) and should definitely be pink .. Quote Link to comment Share on other sites More sharing options...
st3ve Posted 20September, 2021 Report Share Posted 20September, 2021 @Fishcop what type of water pump and the low temp t'stat? We can while away the hours nitpicking those choices too.... While you've got the coolant drained, maybe replace the snappie-offie coolant line connector near the throttle body? Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 20September, 2021 Author Report Share Posted 20September, 2021 @st3veI went with FPC ins the US - good price and reasonable shipping This low-temp unit literally has the original Porsche stamping but the part# is die-ground off https://www.fcpeuro.com/products/porsche-thermostat-wahler-99610601359 FPC do a good kit with everything, but I thought I'd be better off acquiring coolant here in Oz rather than pay for its shipping... https://www.fcpeuro.com/products/porsche-engine-water-pump-and-thermostat-kit-geba-borg-warner-996wtrpmkt1 so went with the low temp thermo and metal impeller pump on their own. Quote Link to comment Share on other sites More sharing options...
st3ve Posted 21September, 2021 Report Share Posted 21September, 2021 Thanks for the info @Fishcop, update the thread with how you get on! Fishcop 1 Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 22September, 2021 Report Share Posted 22September, 2021 The latest revision of the genuine coolant cap is .04 I have them in stock if you need one. Be aware the metal impeller can damage the block if the bearings give out that's why the genuine unit is not metal. http://986forum.com/forums/performance-technical-chat/43533-geba-pump-metal-impeller.html Fishcop and tomo 1 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 23September, 2021 Report Share Posted 23September, 2021 A job I have been planning also. I have vacuum kit for the car and after watching Franny and Heidi’s video, it looks easy! 😳. I was going to buy the Pentosin product through my local Indy. Maybe I should get Stephan to do the whole thing and the water pump also … it has done 50,000kms since 2004. Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 24September, 2021 Author Report Share Posted 24September, 2021 On 23/09/2021 at 08:28, dan_189 said: The latest revision of the genuine coolant cap is .04 I have them in stock if you need one. Be aware the metal impeller can damage the block if the bearings give out that's why the genuine unit is not metal. http://986forum.com/forums/performance-technical-chat/43533-geba-pump-metal-impeller.html Thanks Dan, I read that article (and a couple of others) which is now 8 years old. I'm comfortable that I'll be pushing up daisies before the water pump bearings fail. The metal impeller version just makes sense to me and kilometers I do. I also wasn't actually able to find anyone with a 'first hand' experience of the metal impeller version failing and damaging a block. Raby has done some great work in the Porsche world - but I feel like fear of failure is what's making him rich sometimes. I'll double check the cap version I have - if I don't already have one I'll order a .04 through you. I also just picked up a vacuum filler unit from Sydney Tools for $50 https://sydneytools.com.au/product/daytona-drecoo-cooling-system-refill-kit-and-vacuum-purge I've taken the Penrite back for a refund, now just awaiting the Ravenol. st3ve 1 Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 24September, 2021 Report Share Posted 24September, 2021 Thanks sounds good Also have vacuum filling tools if anyone else needs one. Quote Link to comment Share on other sites More sharing options...
Merv Posted 25September, 2021 Report Share Posted 25September, 2021 I am sure you have seen this one John. Fishcop 1 Quote Link to comment Share on other sites More sharing options...
