Sov Posted 30October, 2021 Report Share Posted 30October, 2021 Is there a trick to removing the centre caps while the wheels are still on the car? Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 30October, 2021 Report Share Posted 30October, 2021 19 minutes ago, the_sovereign_man said: Is there a trick to removing the centre caps while the wheels are still on the car? Should be 2 holes in them, and there should be a hook type thingo in your tool kit to be able to get them off. Otherwise if you have a tool pick, or bend a strong piece of wire you should be able to get them off Quote Link to comment Share on other sites More sharing options...
Sov Posted 30October, 2021 Author Report Share Posted 30October, 2021 4 minutes ago, TwoHeadsTas said: Should be 2 holes in them, and there should be a hook type thingo in your tool kit to be able to get them off. Otherwise if you have a tool pick, or bend a strong piece of wire you should be able to get them off Ahhhh, I did wonder what that hook type thingo (technical name) was for. Now that I'm looking at it, it's totally obvious. Cheers. TwoHeadsTas 1 Quote Link to comment Share on other sites More sharing options...
Carrera28 Posted 30October, 2021 Report Share Posted 30October, 2021 https://www.suncoastparts.com/product/00072192291.html Sov 1 Quote Link to comment Share on other sites More sharing options...
tomo Posted 30October, 2021 Report Share Posted 30October, 2021 1 hour ago, the_sovereign_man said: Ahhhh, I did wonder what that hook type thingo (technical name) was for. Now that I'm looking at it, it's totally obvious. Cheers. Small Allen key also does does the job TwoHeadsTas, P-Kay, Sov and 2 others 4 1 Quote Link to comment Share on other sites More sharing options...
flamingporsche Posted 8November, 2021 Report Share Posted 8November, 2021 Circlip pliers work a treat as well P-Kay, Carrera28 and TwoHeadsTas 3 Quote Link to comment Share on other sites More sharing options...
