Mike D'Silva Posted 26December, 2021 Report Share Posted 26December, 2021 I acquired a car a short while ago with the stock CIS. Car runs well but has high idle speed, which even with the idle bleed screw CLOSED, is still around 1200 rpm when warm! Also, removing the oil cap, made no appreciable difference to the idle speed... Hence, vacuum leaks. I spent some time removing the airbox and all his friends from the engine bay and decided after getting it out, that I wouldn't bother attempting to reinstall it all in the car.... I would pull the engine and install on the test stand... may as well do a valve clearance check etc too. Here is a video I made (sorry, it's not up to the standards of Jeff!) but it shows the leaks on the airbox and also around the pop off valve ... Feel free to scroll through to around halfway to really see the leaks. Another thing I learned, is that baby oil in liquid form might smell nice, but in smoke form, it lingers and is nasty! FAP911, tomo and Peter M 2 1 Quote Link to comment Share on other sites More sharing options...
Coastr Posted 26December, 2021 Report Share Posted 26December, 2021 Looks like it cracked and had a patch up repair done. leaks around blowoff valve from the mounting screws? Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 27December, 2021 Author Report Share Posted 27December, 2021 I don't think it was repaired... and the blowoff valve was installed backwards.. and with very little glue it seems... it's now in the trash.... Engine is back in the car, and hoping to get it buttoned up and fully back on the road today . Quote Link to comment Share on other sites More sharing options...
