911virgin Posted 27January, 2022 Report Share Posted 27January, 2022 hi all any expert advices gratefully accepted! Quote Link to comment Share on other sites More sharing options...
GTP911 Posted 27January, 2022 Report Share Posted 27January, 2022 Larry from Drive Clean goes into detail on options for stone chip touchups, worth the view: Paint Chip Touch-up -- /DRIVE CLEAN - Bing video Quote Link to comment Share on other sites More sharing options...
rminc Posted 27January, 2022 Report Share Posted 27January, 2022 4 hours ago, 911virgin said: hi all any expert advices gratefully accepted! All depends how good of a job you want. Quick repair would be clean with isopropyl alcohol. Apply touch up paint. You can keep going with things like sanding etc. Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 27January, 2022 Report Share Posted 27January, 2022 7 minutes ago, rminc said: All depends how good of a job you want. Quick repair would be clean with isopropyl alcohol. Apply touch up paint. You can keep going with things like sanding etc. Have a look for the thread on Dr Colourchip, fairly recent. I've used with reasonable success, I think I'm happier using that than normal touchup paint which becomes permanent very quickly 🙂 Quote Link to comment Share on other sites More sharing options...
icu_jimmy Posted 27January, 2022 Report Share Posted 27January, 2022 +1 Dr Colourchip. Much more likely of a better result than many other methods. Quote Link to comment Share on other sites More sharing options...
sjm Posted 27January, 2022 Report Share Posted 27January, 2022 +2 Dr Colorchip. Use it on my Seal Grey 997. Distributor in Queensland too. Quote Link to comment Share on other sites More sharing options...
911virgin Posted 28January, 2022 Author Report Share Posted 28January, 2022 thanks people! Quote Link to comment Share on other sites More sharing options...
CoSo Posted 6August, 2023 Report Share Posted 6August, 2023 Coming back to this topic, would people accept a handful of stone chips or get them professionally repaired before doing a full detail/paint protection? There seems to be some hesitation that repainting and matching in can make it look worse than just leaving it alone - if I try and get a high end detailer to do the work instead of just any regular smash repairer, would it still be very noticeable or just on paint gauges? Quote Link to comment Share on other sites More sharing options...
tomo Posted 6August, 2023 Report Share Posted 6August, 2023 6 hours ago, CoSo said: Coming back to this topic, would people accept a handful of stone chips or get them professionally repaired before doing a full detail/paint protection? There seems to be some hesitation that repainting and matching in can make it look worse than just leaving it alone - if I try and get a high end detailer to do the work instead of just any regular smash repairer, would it still be very noticeable or just on paint gauges? Bit like looking at a Sheila @CoSo best to meet them before they have been to the body shop . tomk86 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted 3November, 2023 Report Share Posted 3November, 2023 Dr Colourchip is very good, is easy to apply and blends in really well (but I can usually still see them). Touch-up paint is worse and really only good if you want to protect the bit with missing paint. Fluid pens are the go-to if you want to put work/effort in (and you still need to get your paint match just right), or have someone professionally do it (it's just time-consuming). Larry at Ammo NYC had a good video on a 911: tomo 1 Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 3November, 2023 Report Share Posted 3November, 2023 5 hours ago, Russ said: Dr Colourchip is very good, is easy to apply and blends in really well (but I can usually still see them). Touch-up paint is worse and really only good if you want to protect the bit with missing paint. Fluid pens are the go-to if you want to put work/effort in (and you still need to get your paint match just right), or have someone professionally do it (it's just time-consuming). Larry at Ammo NYC had a good video on a 911: Agree on Dr Colourchip..... Quote Link to comment Share on other sites More sharing options...
