911virgin Posted 29January, 2022 Report Share Posted 29January, 2022 Where actually is this? Not the vin but the build plate. I'm googling and no answer comes up on various Porsche forums🤷 A photo of where it is located would be very much appreciated Some research has suggested in the boot on the right hand front chassis rail? Is the right hand front referring to the drivers side or passenger side? Quote Link to comment Share on other sites More sharing options...
81SC Posted 29January, 2022 Report Share Posted 29January, 2022 25 minutes ago, 911virgin said: Is the right hand front referring to the drivers side or passenger side? Depends if you’re standing on your head 😜 Quote Link to comment Share on other sites More sharing options...
luzzo Posted 29January, 2022 Report Share Posted 29January, 2022 32 minutes ago, 911virgin said: the build plate. Hey @911virgin, Build plate is located on RHS of frunk. That is based on sitting in the car. Ie. Drivers side. So, when standing at front of car looking back into frunk, it would be on your left. However to see it, you will need to pull back frunk carpet liner. Remove left corner plastic retaining clip and pull back carpet to reveal. It is a metal plate riveted to the body (as opposed to some newer cars having a sticker). Hth. tomo and Raven 2 Quote Link to comment Share on other sites More sharing options...
911virgin Posted 29January, 2022 Author Report Share Posted 29January, 2022 Thanks luzzo👍 Will give it a go tomorrow I was close to finding it today.....just didn't pull back carpet enough The plastic bits aren't easy to get back all aligned and flush Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 30January, 2022 Report Share Posted 30January, 2022 They stopped the under bonnet build sticker with 986/996 IIRC. There should also be a copy in the front of your service book from memory. Quote Link to comment Share on other sites More sharing options...
911virgin Posted 30January, 2022 Author Report Share Posted 30January, 2022 All good people Unscrewed the carpet screw, peeled back the carpet and found the two plates👍 tomo 1 Quote Link to comment Share on other sites More sharing options...
