sjm Posted 13February, 2022 Report Share Posted 13February, 2022 Need help with fire extinguisher info, The Bend want a fire extinguisher fitted but only with metal brackets. Any idea what’s suitable. Purchase In SA preferred. Quote Link to comment Share on other sites More sharing options...
LeeM Posted 13February, 2022 Report Share Posted 13February, 2022 Most auto shops have them mate. Supercheap, Autocross etc. There's also the motorsport shop, Autosport on Magill road, Beulah Park. You will probably have to screw or bolt it to the floor. Mine is just in front of the driver's seat for quick access. Would probably only put out a lit candle or three, but it's something I s'pose sjm 1 Quote Link to comment Share on other sites More sharing options...
Dalai Posted 13February, 2022 Report Share Posted 13February, 2022 I bought a couple of Quell Auto extinguishers from Anaconda. Reasonable price and metal double clip bracket. https://www.anacondastores.com/camping-hiking/health-safety/quell-auto-marine-fire-extinguisher/90033423?gclsrc=aw.ds&gclsrc=aw.ds&gclid=Cj0KCQiA0p2QBhDvARIsAACSOONNfS24rIgxeiwOQ9gl3VkHdVc_k0qsJuNNpc_cct6NcKw997JUrtsaAkJ5EALw_wcB You just need to figure how to secure in your car. I have heard good things about KAP Industries brackets. Locally made too! https://kap.industries/product/porsche-fire-extinguisher-mount/ Shedpest and sjm 2 Quote Link to comment Share on other sites More sharing options...
sjm Posted 13February, 2022 Author Report Share Posted 13February, 2022 Yep, tried super cheap and Auto Pro, they’re pretty crap. Will try Autosport tomorrow. One at Parafield also. Cheers. Anaconda might get a look too👍 LeeM 1 Quote Link to comment Share on other sites More sharing options...
Dalai Posted 13February, 2022 Report Share Posted 13February, 2022 Just checked stock levels in Adelaide Anaconda stores. Unfortunately out of stock... But the Quell is Motorsport Australia (previously CAMS) approved. sjm 1 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 13February, 2022 Report Share Posted 13February, 2022 Have you tried ARB or other 4x4 accessory stores ? Quote Link to comment Share on other sites More sharing options...
sjm Posted 13February, 2022 Author Report Share Posted 13February, 2022 9 minutes ago, OZ930 said: Have you tried ARB or other 4x4 accessory stores ? No, but good call😀 24 minutes ago, Dalai said: Just checked stock levels in Adelaide Anaconda stores. Unfortunately out of stock... But the Quell is Motorsport Australia (previously CAMS) approved. Thanks, will check it out. Quote Link to comment Share on other sites More sharing options...
ADS911 Posted 13February, 2022 Report Share Posted 13February, 2022 I had a Rennline bracket that bolted between the front seat rail bolts in my 986 Boxster S, saves drilling holes. From recollection came from James @ Autohaus. Quote Link to comment Share on other sites More sharing options...
sjm Posted 13February, 2022 Author Report Share Posted 13February, 2022 1 hour ago, ADS911 said: I had a Rennline bracket that bolted between the front seat rail bolts in my 986 Boxster S, saves drilling holes. From recollection came from James @ Autohaus. That's the solution I'm aiming for, will check it out. Thanks. Quote Link to comment Share on other sites More sharing options...
JB911 Posted 13February, 2022 Report Share Posted 13February, 2022 I fitted a Kap Industries bracket to my 991 GT3 passenger side seat bolts - easy installation, high quality with supplied high tensile bolts (which Motorsport Australia require). Combine with their extinguisher and shipping is free. However, you need at E12 socket to remove/replace the seat bolts. Don't use a 10mm socket - many have stripped the bolts trying!! sjm 1 Quote Link to comment Share on other sites More sharing options...
Raven Posted 13February, 2022 Report Share Posted 13February, 2022 Are you Guys allowed to use the Fire sticks in SA they meet Aust and NZ standards as required by motorsport Australia and are far superior than a shit 1kg extinguisher unit with less than 10 seconds of extinguisher time. The firesticks have 90 seconds of firefighting time as opposed to the less than 10 seconds you get from those useless 1 kg extinguishers people by at Bunnings and Supercheap auto . If you got a $40 dollar car then buy a $40 dollar extinguisher , just like Helmets and safety apparel , same rule applies when you need it you want it to do the job and protect you and your car .. I run them in both my race cars along with the 2 kg Fire bomb systems , just gives me options in the event of a fire and some extra fire fighting capability if the fire bomb fails to fully suppress the fire after being set off , I have an additional 90 seconds to fight with before the slow , overweight fire marshals arrive ..compact size can be stored in a door pocket or glove box , mounted to a roll cage or to floor etc well worth the money .. https://assentpro.com.au/collections/shop/products/fire-stryker?variant=40055831396546 sjm 1 Quote Link to comment Share on other sites More sharing options...
1q2w3e4r Posted 13February, 2022 Report Share Posted 13February, 2022 6 hours ago, Raven said: Are you Guys allowed to use the Fire sticks in SA they meet Aust and NZ standards as required by motorsport Australia and are far superior than a shit 1kg extinguisher unit with less than 10 seconds of extinguisher time. The firesticks have 90 seconds of firefighting time as opposed to the less than 10 seconds you get from those useless 1 kg extinguishers people by at Bunnings and Supercheap auto . If you got a $40 dollar car then buy a $40 dollar extinguisher , just like Helmets and safety apparel , same rule applies when you need it you want it to do the job and protect you and your car .. I run them in both my race cars along with the 2 kg Fire bomb systems , just gives me options in the event of a fire and some extra fire fighting capability if the fire bomb fails to fully suppress the fire after being set off , I have an additional 90 seconds to fight with before the slow , overweight fire marshals arrive ..compact size can be stored in a door pocket or glove box , mounted to a roll cage or to floor etc well worth the money .. https://assentpro.com.au/collections/shop/products/fire-stryker?variant=40055831396546 I do the same thing, I have the extinguisher as needed, but a couple of these in the cars as well. I'd reckon they'd do better than the extinguisher in case of a fire, but hope to never find out. Raven and sjm 1 1 Quote Link to comment Share on other sites More sharing options...
sjm Posted 13February, 2022 Author Report Share Posted 13February, 2022 6 hours ago, Raven said: Are you Guys allowed to use the Fire sticks in SA they meet Aust and NZ standards as required by motorsport Australia and are far superior than a shit 1kg extinguisher unit with less than 10 seconds of extinguisher time. The firesticks have 90 seconds of firefighting time as opposed to the less than 10 seconds you get from those useless 1 kg extinguishers people by at Bunnings and Supercheap auto . If you got a $40 dollar car then buy a $40 dollar extinguisher , just like Helmets and safety apparel , same rule applies when you need it you want it to do the job and protect you and your car .. I run them in both my race cars along with the 2 kg Fire bomb systems , just gives me options in the event of a fire and some extra fire fighting capability if the fire bomb fails to fully suppress the fire after being set off , I have an additional 90 seconds to fight with before the slow , overweight fire marshals arrive ..compact size can be stored in a door pocket or glove box , mounted to a roll cage or to floor etc well worth the money .. https://assentpro.com.au/collections/shop/products/fire-stryker?variant=40055831396546 Great option, thanks for pointing it out Raven. Will check with the track but they stipulate metal brackets for 1kg extinguisher. Quote Link to comment Share on other sites More sharing options...
Raven Posted 13February, 2022 Report Share Posted 13February, 2022 Instal what they require and grab one of these and keep it in the glove box or door pocket as your primary go to if you ever have to use it , I have seen cars burn after a Driver used useless 1 KG extinguishers and then stood helpless waiting for the Fire marshals to arrive .. sjm 1 Quote Link to comment Share on other sites More sharing options...
Shedpest Posted 13February, 2022 Report Share Posted 13February, 2022 The Big Green shed https://www.bunnings.com.au/search/products?q=fire extinguisher&sort=BoostOrder&page=1 The place on Magill road has these brackets and extinguishers https://www.autosport.com.au/autosport-universal-extinguisher-bracket https://www.autosport.com.au/fire-systems sjm 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 13February, 2022 Report Share Posted 13February, 2022 2 hours ago, Raven said: Instal what they require and grab one of these and keep it in the glove box or door pocket as your primary go to if you ever have to use it , I have seen cars burn after a Driver used useless 1 KG extinguishers and then stood helpless waiting for the Fire marshals to arrive .. Like that blue air cooled from WA at the Adelaide rally coupla 3 years ago. Think it was 9 extinguishers used, but it still burnt to the ground 4 shown here Raven, sjm, 81SC and 1 other 4 Quote Link to comment Share on other sites More sharing options...
sydr Posted 13February, 2022 Report Share Posted 13February, 2022 10 hours ago, Raven said: Are you Guys allowed to use the Fire sticks in SA they meet Aust and NZ standards as required by motorsport Australia and are far superior than a shit 1kg extinguisher unit with less than 10 seconds of extinguisher time. The firesticks have 90 seconds of firefighting time as opposed to the less than 10 seconds you get from those useless 1 kg extinguishers people by at Bunnings and Supercheap auto . If you got a $40 dollar car then buy a $40 dollar extinguisher , just like Helmets and safety apparel , same rule applies when you need it you want it to do the job and protect you and your car .. I run them in both my race cars along with the 2 kg Fire bomb systems , just gives me options in the event of a fire and some extra fire fighting capability if the fire bomb fails to fully suppress the fire after being set off , I have an additional 90 seconds to fight with before the slow , overweight fire marshals arrive ..compact size can be stored in a door pocket or glove box , mounted to a roll cage or to floor etc well worth the money .. https://assentpro.com.au/collections/shop/products/fire-stryker?variant=40055831396546 Fascinated by this; I really like the idea. But I can't find objective reviews relating to its effectiveness or otherwise. Has anyone any insight? A note of caution relating to buying off the shelf extinguishers - some might cause enough damage to make you wish you'd let the fire rip. Apart from the mess that the powder makes, I've heard that certain types leave a corrosive residue so that after a year or two your electronics start failing. I believe that Simply Sports Cars - Lotus distributor in Sydney - may have the correct type, worth a phone call and a question about corrosive elements. LeeM and sjm 1 1 Quote Link to comment Share on other sites More sharing options...
hugh Posted 14February, 2022 Report Share Posted 14February, 2022 The purpose of a fire extinguisher in the car is to allow for you, as the driver, to use if required to exit/extract yourself from a car that has caught on fire. Once a car goes up you will struggle with any number of extinguishers to put it out and depending on fuel loads etc. it's a frustratingly pointless exercise - they aren't designed for fires of that intensity. I was present when that blue car pictured above went up in Adelaide and the only way for it to get put out was with a fire truck. Even then, as others have mentioned above, the chemicals in the extinguishers are so corrosive it pretty much destroys everything that doesn't get burnt anyway. sjm, LeeM and Peter M 2 1 Quote Link to comment Share on other sites More sharing options...
sjm Posted 14February, 2022 Author Report Share Posted 14February, 2022 3 hours ago, Shedpest said: The Big Green shed https://www.bunnings.com.au/search/products?q=fire extinguisher&sort=BoostOrder&page=1 The place on Magill road has these brackets and extinguishers https://www.autosport.com.au/autosport-universal-extinguisher-bracket https://www.autosport.com.au/fire-systems Heading there today (auto sport) to have a look. Cheers. 1 hour ago, LeeM said: Like that blue air cooled from WA at the Adelaide rally coupla 3 years ago. Think it was 9 extinguishers used, but it still burnt to the ground 4 shown here i remember when that happened. Fuel fire/loose fuel line? Can only imagine how the owner felt.😟 LeeM and Shedpest 2 Quote Link to comment Share on other sites More sharing options...
Shedpest Posted 14February, 2022 Report Share Posted 14February, 2022 @sjm are you booked for the GT Circuit on the 20th? Quote Link to comment Share on other sites More sharing options...
sjm Posted 14February, 2022 Author Report Share Posted 14February, 2022 3 hours ago, Shedpest said: @sjm are you booked for the GT Circuit on the 20th? Yes, that’s the one. Haven’t been on The Bend yet.looking forward to a fang without looking over my shoulder for cops and cameras. Are you entered as well. Settled for this setup from Autosport on the end. Quote Link to comment Share on other sites More sharing options...
Shedpest Posted 14February, 2022 Report Share Posted 14February, 2022 @sjm should be a fun day, kudos for doing the GT track if you haven't been there before, there are a lot of corners, best to start watching a few videos. I won't be attending on the 20th but am keen in March for the GT track on the bike. sjm 1 Quote Link to comment Share on other sites More sharing options...
Gavn Posted 14February, 2022 Report Share Posted 14February, 2022 Second what others have mentioned here - the 1kg jobs are only for small spot/smouldering fires or to buy you time to get out of the cabin. If the engine area is on fire (and you know what you're doing), you may be able to lift the lid and get a bit more time/less damage prior to a truck arriving. However lifting that rear lid with a fire is going is a big decision... You're most definitely not going to put out anything serious with any number of 1kg detectors unless you're right on top of the seat of the fire and hitting it just right (ie if your'e not lifting the rear lid, you've got not chance). Those sticks are good but, again, need to be applied just right so I'd suggest buying half a dozen and playing with four of them & fires in metal buckets until you're confident using them. Not much point trying first time when the pressure is on. sjm 1 Quote Link to comment Share on other sites More sharing options...
sjm Posted 14February, 2022 Author Report Share Posted 14February, 2022 10 hours ago, Shedpest said: @sjm should be a fun day, kudos for doing the GT track if you haven't been there before, there are a lot of corners, best to start watching a few videos. I won't be attending on the 20th but am keen in March for the GT track on the bike. What!!!…it’s not on my satnav😅. Good idea though, sure there’s plenty on yootoob. Quote Link to comment Share on other sites More sharing options...
Dalai Posted 14February, 2022 Report Share Posted 14February, 2022 13 hours ago, Gavin (CliffToCoast) said: Second what others have mentioned here - the 1kg jobs are only for small spot/smouldering fires or to buy you time to get out of the cabin. If the engine area is on fire (and you know what you're doing), you may be able to lift the lid and get a bit more time/less damage prior to a truck arriving. However lifting that rear lid with a fire is going is a big decision... Which is why I recently bought a couple of Blazecut's https://www.flameout.com.au/blazecut from Mark Clair. Quote Link to comment Share on other sites More sharing options...
