911virgin Posted 28February, 2022 Report Share Posted 28February, 2022 Hey all, Any places in Melbourne to get these at a decent price? I'm not looking for the OEM key/ remote but the flatter rectangular thing you can press to open/ close /lock the car ( when the OEM key/ remote has carked it) Sorry I can't post a photo/ link Looking on eBay Australia without success Any advices much appreciated Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 28February, 2022 Report Share Posted 28February, 2022 Like the photo attached, Look up SpecIalised ECU Repairs in the US, you will need to advise on the frequency required when ordering. Buy two as I need a spare. Quote Link to comment Share on other sites More sharing options...
911virgin Posted 28February, 2022 Author Report Share Posted 28February, 2022 hey WB997 thanks for the photo- that is the thing i mean, yes how do you work out the frequency required? assume that is unique for each car? Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 1March, 2022 Report Share Posted 1March, 2022 Usa is 315mhz, Europe and (ROW) is 433mhz. If you open your existing fob you will most probably find frequency tag inside. I’ll check mine when I’m home. Their site also has a coding sequence PDF. Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 2March, 2022 Report Share Posted 2March, 2022 You can confirm the frequency by checking the code on the face of the Immobiliser, mine is 315.05mhz. Its located under the passengers seat. Quote Link to comment Share on other sites More sharing options...
pocketscience Posted 12April, 2022 Report Share Posted 12April, 2022 Late ato the party, but do you have the original switch blade key? I'm not sure when they changed to that but I've just changed over my '97 993 from the switch blade key (which sucks), to the seperate key and remote setup like my '95 993. The guts of the remote moves over to the new case without any hassle - it's identical. The key head can be liberated from the switch blade setup and moved into a standard key head in a few minutes as well. I looked at 3rd party stuff but ended up buying the empty remote case and key head from Porsche. No mucking about with reprogramming remotes etc. Quote Link to comment Share on other sites More sharing options...
911virgin Posted 13April, 2022 Author Report Share Posted 13April, 2022 21 hours ago, pocketscience said: Late ato the party, but do you have the original switch blade key? I'm not sure when they changed to that but I've just changed over my '97 993 from the switch blade key (which sucks), to the seperate key and remote setup like my '95 993. The guts of the remote moves over to the new case without any hassle - it's identical. The key head can be liberated from the switch blade setup and moved into a standard key head in a few minutes as well. I looked at 3rd party stuff but ended up buying the empty remote case and key head from Porsche. No mucking about with reprogramming remotes etc. i have the original swtich blabe key. what did the remote fob and seperate key parts cost from porsche? Quote Link to comment Share on other sites More sharing options...
pocketscience Posted 14April, 2022 Report Share Posted 14April, 2022 On 13/04/2022 at 14:05, 911virgin said: i have the original swtich blabe key. what did the remote fob and seperate key parts cost from porsche? All up around $230. You should be able to do the same with the cheaper 3rd party bits off ebay or wherever. If you do go with original these are the part numbers: Fob: 993.618.959.12 Key head: 944.538.041.01 Quote Link to comment Share on other sites More sharing options...
911virgin Posted 14April, 2022 Author Report Share Posted 14April, 2022 hey thanks so much PS i will go original pocketscience 1 Quote Link to comment Share on other sites More sharing options...
pocketscience Posted 20April, 2022 Report Share Posted 20April, 2022 You can't go wrong with original.. Quote Link to comment Share on other sites More sharing options...
911virgin Posted 22April, 2022 Author Report Share Posted 22April, 2022 On 20/04/2022 at 12:01, pocketscience said: You can't go wrong with original.. Definitely! No messing around with entering codes etc on a generic fob Quote Link to comment Share on other sites More sharing options...
