Bibbs Posted 26July, 2022 Report Share Posted 26July, 2022 I was annoyed with the standard 987 key having lock/unlock on the same button. So I've done a thing. Here are the basic functions working, and a nice new style key. YouTube video Will now look into the auto lock/unlock stuff. P-Kay and reggiegums 2 Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 27July, 2022 Report Share Posted 27July, 2022 Cool, do you have write up. I have recently modified my 993 to flash the indicators when locking & unlocking the car. Quote Link to comment Share on other sites More sharing options...
Bibbs Posted 27July, 2022 Author Report Share Posted 27July, 2022 It's all from a kit on Ali Express ~$400 It daisy chains off the stock ignition barrel and the steering wheel CanBus controller, and a brake pedal and ground fly leads. Also requires a disassembled key to be solded into a box and plugged into the new loom. Taking the driver's side lower dash apart and putting it all back took longer than actually installing. Quote Link to comment Share on other sites More sharing options...
Bibbs Posted 1August, 2022 Author Report Share Posted 1August, 2022 So to add more information. It was this kit - https://a.aliexpress.com/_mthlsR0 You have to pull apart a key and solder it into the new loom. Setup the PKE so the car auto unlocks when the keys are within a few feet of the car. Tidied up the fusebox with a pair of fuse taps. One for the aftermarket headunit (to ignition), one so the orange brake so the start/stop doesn't need the brake depressing (to constant 12v). So a tap of the button turns the ignition on, or clutch in and hold to start the car. Quote Link to comment Share on other sites More sharing options...
