Headlight removal for 996.2 with Litronics (and washer)
Hi,
I've seen lots of YT videos on the simplicity of removing the headlights but not found one that addresses what needs to be done differently, if at all, for headlights that have washers.
Is there something you ned to do to the washer before ejecting the headlight assembly?
Many thanks
Nope. Removal is the same as all 996's. Remove the plug, turn hex nut, pull assembly forward. Don't even need to remove the power cable anymore as this just unplugs as its part of the assembly instead of like earlier models which have a seperate cable.
