Niko Posted 3August, 2014 Report Share Posted 3August, 2014 AOS is a reasonably easy job on the 986's according to my workshop. (Easy for him to say though) Not being too Porsche mechanically minded myself though, it would probably be a monster job if I stupidly took it on. Quote Link to comment Share on other sites More sharing options...
firstone Posted 3August, 2014 Report Share Posted 3August, 2014 My money is on the air/oil separator. I would also be looking at my plugs. They tell you are great deal. New ones can make such a difference. I had a Cayman 2.7 but I must admit I am not sure how easy they are to get at. Yeah has the classic high vacuum at the oil cap as well. AOS is a reasonably easy job on the 986's according to my workshop. (Easy for him to say though) Not being too Porsche mechanically minded myself though, it would probably be a monster job if I stupidly took it on. Not an easy one but I enjoy the challenge. I'm not Porsche mechanically minded but I'm learning. Pelican has a good tutorial as usual. With his and others gives a well rounded look at the job before hand. Quote Link to comment Share on other sites More sharing options...
Bobbyg Posted 22June, 2015 Report Share Posted 22June, 2015 It's normal for your car to "clear its throat" very occassionally. If it gets worse, then it's the air / oil seperator which needs servicing. The engine air-oil separator is an emissions device that is responsible for collecting residual gases and vapours contained inside the crankcase and funnelling them back into the intake manifold where they can be burned in the combustion chamber. This reduces the overall emissions of the engine. When the separator fails, you will begin to see a large increase in the overall vacuum in the engine crankcase. In the most extreme cases, the air-oil separator fails to separate the oil from the air and oil is then sucked into the intake manifold. Oil in the intake system is not healthy for the engine and it can foul spark plugs and destroy catalytic converters at the very least. The failure of the air-oil separator is often but not always, accompanied by huge amounts of white smoke exiting the vehicle's exhaust and a generally poor running engine. You may experience a check engine light (CEL) as the oil being drawn into the intake can affect the mixture level. The oil cap may be very difficult to remove when the engine is running due to high vacuum levels. In addition, you may hear a high-pitched squeal from the engine when it's running because air is being sucked in past the crankcase seal due to the extreme vacuum inside the case. Thank you so very much mate, you're a saviour. This happened to me this morning, the smoke and all, but it started with the loud embarrasing squealing sound in the middle of the city on Wednesday night. After that I drove home as if nothing was wrong but this morning, I could have easily been sending smoke messages to the Indians, thinking it was a blown gasket or something more sinister. I will hope it's the AOS which is not a bad fix. Thanks to all guys. Quote Link to comment Share on other sites More sharing options...
Niko Posted 22June, 2015 Report Share Posted 22June, 2015 Hi Bobbyg, welcome to our forum. Hopefully..and it certainly sounds like the AOS Please come back and let us know how you went. An update on how much the job (if it is the AOS) now costs would be good too. Good luck with it Quote Link to comment Share on other sites More sharing options...
gsbeamer Posted 26September, 2020 Report Share Posted 26September, 2020 Hello everyone, I am a Newbe to this Forum and you guys sure seem to know your stuff, I have a 2010 Boxster S and have the White smoke on start up problem also, but after sitting in the Shed for the last 4-5 days I went out on purpose to start the car and had my stop watch ready to see how long the white smoke came out before it stopped, because it smokes for awhile then seems to stop, anyway I started the car hit the stop watch and jumped out of the car to go and have a look and time how long before the smoke goes away, but this time it dident smoke at all, not at all I am going to get it fixed next week when I take it for a service. My question to you guys should it be OK to drive it 450 Ks to the service center or not. Regards Sean. Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 26September, 2020 Report Share Posted 26September, 2020 4 minutes ago, gsbeamer said: Hello everyone, I am a Newbe to this Forum and you guys sure seem to know your stuff, I have a 2010 Boxster S and have the White smoke on start up problem also, but after sitting in the Shed for the last 4-5 days I went out on purpose to start the car and had my stop watch ready to see how long the white smoke came out before it stopped, because it smokes for awhile then seems to stop, anyway I started the car hit the stop watch and jumped out of the car to go and have a look and time how long before the smoke goes away, but this time it dident smoke at all, not at all I am going to get it fixed next week when I take it for a service. My question to you guys should it be OK to drive it 450 Ks to the service center or not. Regards Sean. Smoke on startup quite normal, particularly if it has sat for a few days. Easy solution, drive it every day 🙂 Seriously though, do a search on this forum and on the 'net generally, and you'll find heaps of similar questions and answers. And welcome to the forum 🙂 Quote Link to comment Share on other sites More sharing options...
Pork Chops Posted 26September, 2020 Report Share Posted 26September, 2020 I got a 2.9l DFI boxster with the AOS done. Did 4 track days over 8 days and about 3,000 klms of hard driving in between and about 2/3 the way through I'd occassionally get white smoke on start up. Threw it at the mechanic after the tour was over and he couldn't replicate. Sounds like a 'thing'. My car runs great. No issues at all. Thrashed the balls off it. You'll be right. Quote Link to comment Share on other sites More sharing options...
Arne Krix Posted 26September, 2020 Report Share Posted 26September, 2020 On 23/06/2015 at 06:55, Niko said: Hi Bobbyg, welcome to our forum. Hopefully..and it certainly sounds like the AOS Please come back and let us know how you went. An update on how much the job (if it is the AOS) now costs would be good too. Good luck with it Looks like I’ll be talking to you when the time comes 🙂 Quote Link to comment Share on other sites More sharing options...
Niko Posted 27September, 2020 Report Share Posted 27September, 2020 1 hour ago, Arne Krix said: Looks like I’ll be talking to you when the time comes 🙂 I'll be here....I'm not allowed to go anywhere Quote Link to comment Share on other sites More sharing options...
Arne Krix Posted 27September, 2020 Report Share Posted 27September, 2020 1 hour ago, Niko said: I'll be here....I'm not allowed to go anywhere I mean in relation to 'white smoke ' coming out of my exhaust. Niko 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 28September, 2020 Report Share Posted 28September, 2020 Smoke on start up is an event from time to time on all the flat 6's, especially 996 Turbos (no AOS) which have a different cool down technique required to clear the turbo oil feed check valves. White smoke and copious amounts of it however is a different matter. A decent mechanic can check the capacity of the AOS to hold a vacuum. If it is on the way out its not a difficult fix. Quote Link to comment Share on other sites More sharing options...
Gnrnr Posted 30September, 2020 Report Share Posted 30September, 2020 Update on my white smoke. I had the car serviced yesterday and after replacing the AOS, the smoke is gone. I've only done the single start when I picked the car up so far and will do a few more checks of the next week or so. Stepo and Mike D'Silva 2 Quote Link to comment Share on other sites More sharing options...
Gnrnr Posted 2April, 2021 Report Share Posted 2April, 2021 I should report back that after about 8 or 9,000km it is still fine. Only used about 500ml of oil in that time. firstone 1 Quote Link to comment Share on other sites More sharing options...
