964 window washer
Hughesy
Good evening gentlemen. As I trowel through the projects to get my P near to perfection (in my eyes) I figure I will be needing your help please.
So the latest problem sorry project is the window washer. Is it the same pump for the headlights as for the windscreen.. ... The headlights wash magnificently yet the windscreen does not work at all.. I've pulled apart all tubing and clear all lines but still no joy..
Next project is to repair the rear spoiler.. There is a crack in the car colour matched Frame that surrounds the air grill.. I will need to remove this to glue it back together.. Is this tricky or as simple as it first appears
Any hints to solve these projects will be greatly appreciated thank you
Hughesy.
PS. Just back from a 120klm blast. Gotta love these cars. :-)
On my 964 there one way valves that had become blocked over time. I replaced them and now the windscreen washers work like new.
It seems that most 964 over time suffer from a crack in the spoiler frame-I have read numerous posts about repairs but I still unable to find one that did not involve high costs or were only temporary. Mine has the same crack for at least the last 5 years- it never gets worst or effects the operation.
  • 1 year later...
I'm having similar problems with 993 have replaced motor valves etc still have very little flow.  Curiously when I first drive it I can get flow but once I let go of the switch that's it for the day.  I'm worried it is the control stalk but all other controls work and the pump motor goes, any ideas?
