Caledonian Posted 17April, 2014 Report Share Posted 17April, 2014 Don't really want to start another huge oil debate, just coming up for an oil change and thought i would see what the consensus was out there? My car had an engine rebuild 6 years and around 12K prior to my purchase, in that time and according to the receipts suppled it had 4 oils changes 2 with Fuch Fully synthetic and 1 with Mobil 1 (Porsche dealer) and one just stated as 10lt of fully synthetic oil? When I got the car i researched the which oil question to the point of brain ache! I ended up talking to one of the local independent Porsche specialists and they said they used (and importantly had been using for some time) they recommend Castrol Magnatec 10-40 Semi - Synthetic so that was what ended up going for. I don't drive like Miss Daisy and I don't cane the backside off the car either, I would like to do an occational track day in the future but not on the cards at the moment. I intend to change the oil and filter annually or 10000km whichever comes 1st. The car got a major service in July 2013 and by the time that comes around this year I estimate I will have done around 6500 - 7500km. Please share your experiences and thoughts. Quote Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Report Share Posted 17April, 2014 as you're running synthetic I think you're best to stick with it I run that Penrite stuff - HPR30 20w60 (I think, i'll have to check the bottle when I get home) Quote Link to comment Share on other sites More sharing options...
CarreraG50 Posted 17April, 2014 Report Share Posted 17April, 2014 Oh goody an oil thread Brad Penn 20w50 is my poison. I'm sure you've seen the oil thread on the bird, you can lose days in there. Change it often, keep it clean, seems to be the best advice.(but you already do that) Caledonian, Doish13 and clutch-monkey 3 Quote Link to comment Share on other sites More sharing options...
JustJames Posted 17April, 2014 Report Share Posted 17April, 2014 as you're running synthetic I think you're best to stick with it I run that Penrite stuff - HPR30 20w60 (I think, i'll have to check the bottle when I get home) This is not necessarily true. Synthetic oils are vastly superior to dinosaur based on every technical measure. BUT (and it's a BIG but), aircooled engines need ZDDDPPPDDPPDPPDPPDPPDDDP, which stands for Zinc something or other. Mobil 1 is great for water cooled engines. From memory, cars up to 964 need a mineral oil with ZDDDPP etc. 993's should get semi synth and water cooled boxers should get fully synthetic. Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 This is not necessarily true. Synthetic oils are vastly superior to dinosaur based on every technical measure. BUT (and it's a BIG but), aircooled engines need ZDDDPPPDDPPDPPDPPDPPDDDP, which stands for Zinc something or other. Mobil 1 is great for water cooled engines. From memory, cars up to 964 need a mineral oil with ZDDDPP etc. 993's should get semi synth and water cooled boxers should get fully synthetic. Yes James importance of the Zinc content is the deal breaker I believe? Just to keep this thread on track can I suggest you post as follows: Type/Brand Oil used and how long Driving style,car usage Then we can get into the debate:) Quote Link to comment Share on other sites More sharing options...
pocketscience Posted 17April, 2014 Report Share Posted 17April, 2014 993's should get semi synth Your guys put fully synthetic 5w/50 mobil 1 in my 993 recently... and I recall from when I originally picked it up Scott saying that was the preference? I think the biggest problem is that opinions on which oil to use are like belly-buttons... everybody has one. Caledonian 1 Quote Link to comment Share on other sites More sharing options...
Chris-p Posted 17April, 2014 Report Share Posted 17April, 2014 1) Nulon Street and Track Full Synth 15W/50. It gets changed every 12 months 2) Pedestrian Ave 2500km per year. Storm 1 Quote Link to comment Share on other sites More sharing options...
CarreraG50 Posted 17April, 2014 Report Share Posted 17April, 2014 I just did some reading up on PENRITE, 10TENTHS 10W-40 has ZINC 2200+ PPM (full synth) HPR30 20W-60 has approx. 1600ppm (yep they said approx.????) Classic Light 20W-60 has High Zinc (no PPM given) I think we need at least 1200ppm for our Air Cooled contraptions. The other good one is Valvoline VR-1(so I'm told) available at REPCO. Good luck Caledonian 1 Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 I just did some reading up on PENRITE, 10TENTHS 10W-40 has ZINC 2200+ PPM (full synth) HPR30 20W-60 has approx. 1600ppm (yep they said approx.????) Classic Light 20W-60 has High Zinc (no PPM given) I think we need at least 1200ppm for our Air Cooled contraptions. The other good one is Valvoline VR-1(so I'm told) available at REPCO. Good luck So what do you use? sorry Brad Penn you said.... where do you get it? Quote Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Report Share Posted 17April, 2014 This is not necessarily true. Synthetic oils are vastly superior to dinosaur based on every technical measure. BUT (and it's a BIG but), aircooled engines need ZDDDPPPDDPPDPPDPPDPPDDDP, which stands for Zinc something or other. Mobil 1 is great for water cooled engines. From memory, cars up to 964 need a mineral oil with ZDDDPP etc. 993's should get semi synth and water cooled boxers should get fully synthetic. I was more making the point if you switch from Synthetic back to Mineral a lot of the times some seals don't like it and you get random oil leaks. I know a few VW people with Type 4 motors that have done this I agree on the zinc for lubrication (although no one ever used to worry about it until the past 10-15 years) Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 I suppose what i'm looking for here is what oils people have been using and for how long: e.g. Bob used ABC blah blah oil for the last 8 years and 60k with no problems. Quote Link to comment Share on other sites More sharing options...
SteveF Posted 17April, 2014 Report Share Posted 17April, 2014 I am using Mobil Super 1000 20W-50 as this is what was suggested to me from AH. Quote Link to comment Share on other sites More sharing options...
GregAx Posted 17April, 2014 Report Share Posted 17April, 2014 I did my first oil change on the 930 and used Liquimoly 20-50. Its a mineral grade oil recommended for that car also made in Germany. http://www.liqui-moly.com.au/products/motor-oil/ Quote Link to comment Share on other sites More sharing options...
Doish13 Posted 17April, 2014 Report Share Posted 17April, 2014 Theo got me onto Brad Penn and I rate it cause of it's fluro green colour that adds about 5kw at the wheels and as it comes in quarts it's extra 2 bottles are perfect top up bottles for later on. Very happy with the product and the free stickers it comes with. Distributor in Sydney does over night deliver for $12 or so. Quote Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Report Share Posted 17April, 2014 http://www.penriteoil.com.au/engineoils-products.php?id_categ=1&id_products=4 That's the stuff I use, have for 3 changes in almost 2 years. Does bump up the consumption a bit though Quote Link to comment Share on other sites More sharing options...
Harvs11 Posted 17April, 2014 Report Share Posted 17April, 2014 I agree on the zinc for lubrication (although no one ever used to worry about it until the past 10-15 years) In the last 10 years zinc has been reduced for enviro. benefit (and possibly other reasons). Hence the recent discussions. Newer engines are designed for low zinc oil. Older engines still need the zinc to protect the wear surfaces, particularly the flat tappet valve trains in pre-993 air cooled engines. Finding the zinc content in oils can be difficult but worth knowing to be safe. Min. 1200ppm is supposedly the safe minimum. I'm currently using Castrol Edge Titanium 25w-50. Doish13 and Caledonian 2 Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 In the last 10 years zinc has been reduced for enviro. benefit (and possibly other reasons). Hence the recent discussions. Newer engines are designed for low zinc oil. Older engines still need the zinc to protect the wear surfaces, particularly the flat tappet valve trains in pre-993 air cooled engines. Finding the zinc content in oils can be difficult but worth knowing to be safe. Min. 1200ppm is supposedly the safe minimum. I'm currently using Castrol Edge Titanium 25w-50. Interesting, i was just looking up the Castrol website and Edge Titanium 25w-50 is their recommendation for my car, but i'm sure there were others before when i looked last year? Did you find out if it meets the ZDDP 1200ppm requirement ? have you been using it for long or is it new to the market? Sorry for all the questions... Quote Link to comment Share on other sites More sharing options...
Harvs11 Posted 17April, 2014 Report Share Posted 17April, 2014 Interesting, i was just looking up the Castrol website and Edge Titanium 25w-50 is their recommendation for my car, but i'm sure there were others before when i looked last year?Did you find out if it meets the ZDDP 1200ppm requirement ? have you been using it for long or is it new to the market?Sorry for all the questions...Edge Titanium is replacement for Edge Sport which had 1200ppm Zn. Castrol are very cagey with product info. so I haven't been able to confirm the exact numbers. I was previously running Liqui-moly Synthoil Race Tech GT1 SAE 10W-60. It might have been coincidence but my oil leaks started after I began using 10W-60. Full synthetic is not recommended for newly rebuilt engines (new rings along with head stud replacement less than 1000kms ago) So far the engine is running well. Quote Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Report Share Posted 17April, 2014 That penrite oil is 1570ppm zinc btw Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 According to this the API ratings have changed and this issue in now even more vague.... http://blog.hemmings.com/index.php/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines/ Quote Link to comment Share on other sites More sharing options...
Harvs11 Posted 17April, 2014 Report Share Posted 17April, 2014 Some bedtime reading... http://speedtalk.com/forum/viewtopic.php?t=30483 Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 Can't you just give me the answer:) Quote Link to comment Share on other sites More sharing options...
CarreraG50 Posted 17April, 2014 Report Share Posted 17April, 2014 There are two stockists for Brad Penn in the BrisVegas area-: Ian Boetcher race parts, 30 Belar St. 3281 1219 (this is where I buy it from, as they always look after me with price) Rapid, 75 Logan River Road 0418 180 734 Last time I bought it was around $120:00 for 12 litres ($10/litre) Don't forget most other oils come in 5lt containers. When comparing with Brad Penn remember your 2 "extra" litres. Quote Link to comment Share on other sites More sharing options...
550Spyder Posted 17April, 2014 Report Share Posted 17April, 2014 (1) I have used Penrite extra ten for three years in my race engine. Formula ford need the zinc. I monitor oil pressure pretty carefully under race conditions and am a believer. http://www.penriteoil.com.au/tech_pdfs/1192%20February%202014%20-%20Automotive%20Engine%20Oil%20Summary.pdf Used brad penn in my 550 Spyder but to be honest it couldn't hold oil pressure when hot (dropped very low at idle as is suspect oil was too hot), suspect I needed to go up the range in grade to a thicker oil. Quote Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Author Report Share Posted 17April, 2014 "Last time I bought it was around $120:00 for 12 litres ($10/litre)" Thats not too bad and comparative to what i paid for the castrol.... Quote Link to comment Share on other sites More sharing options...
